Question about Top Knobs M826 Door Pull
I have an emtek exterior door lock, that is stuck in the locked position. I can only open it with a key, and not even the inside unlock mechanism will permanently unlock it. I took it apart as much as i could but cannot figure out how to disassemble the outside piece. There seems to be a small pinhole opening, but i can't figure out how it disassembles.
  • 576 Answers
If the opening is on the side, it probably comes off by pushing a small tool (pick or large paper clip) into the hole while turning the key. When you feel the pin move, pull on the knob and it should come off.
Posted on Nov 20, 2009
Drivers side door closed and will not open.
Remove inner door latch and try operating the rod manually (vice grips). If locked, spray everything inside the door with WD-40 or the like and try operating the lock.
Aug 15, 2016 | 2011 Honda Fit Sport
2006 Nissan Sentra. Right passenger door wouldn't open from outside, then my kid turned on the interior child lock, meaning the door is unable to be opened from either side. Where do I go from here? C
2 or 4 door? If 2, you should still be able to use key on exterior, and I don't think they have a child lock on 2 doors, so I'm guessing 4. With car unlocked, can't you open rear doors from outside even with child lock on?
Jan 13, 2015 | 2006 Nissan Sentra 1.8
Does anyone have a solution to fix my driver door locking mechanism? When I press the key fob to unlock the car doors. All the car doors unlock except for the driver door. However if you open the driver...
General advise:The lock is not ok.The same wires that lock the doors,unlock it.Before removing the lock:ceck fuses,door wiring link (near the door hinges)U may have to figure out the link covered in removabile rubber(it has a lock pin and must pull down in some cars rotate)U can clean it by air gun and contact cleaner.Rare:The door unlock pin (small plastic knob that u unlock manually from inside)has the rod dirty/stucked/twisted,ceck it to move loose.Also spray chain lube and wd40 anywhere in the lock u gain acces (the key hole,from sides,from the pin lock).U can see if it is stucked if the unlock knob has the intention to rise (small moves) but does not pop.Cheers.
Oct 24, 2013 | 2005 Renault Clio 1.5
My drivers side rear door will not open from the inside or outside
I had exact problem Santa Fe 2007 2008 lock was stuck in locked position and door would not open from inside or out. All other doors would unlock with auto key remote. Carefully work the inside lock towards the open position as you lock and unlock the door with the remote. As you press unlock try to assist the lock to open. I did this a few times and the lock became free to the open position and all worked perfectly after this.
Feb 02, 2013 | 2007 Hyundai Santa Fe Limited
Pajero 4d56 front drivers door wont open from inside and outside locking mechanism is stuck at lock position but all other doors work fine. problem is how to open without breaking anything need help
it could be like my truck. try putting your wieght into the door and try unlocking it with the key while doing that. just dont force it and break the key off inside the lock
Nov 24, 2012 | Cars & Trucks
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible...
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Oct 02, 2010 | Top Knobs M826 Door Pull
Passenger door will not open
I can think of two possibilities:
1) The electronic lock is malfunctioning and forcing the door to lock. From the inside of the car, try forcing the lock to the 'unlocked' position. If you can do this with your had, but it 'snaps' back to 'locked' then it's an electrical problem. Possibly the lock solenoid itself, or the BCM.
2) If you cannot force the lock to the 'unlocked' position, then it's some sort of mechanical problem - maybe the lock is just jammed. Try spraying oil into the locking mechanism from the outside and working the lock until it's free. Otherwise, remove the interior door panel and diagnose the mechanical lock.
Feb 01, 2010 | 2003 Hyundai Tiburon
Can't take apart an EMTEK entry set
Hope I can help! I have worked with Emtek before and some of the front plates are secured with screws from the the other side of the door. You may want to check if this is the case. if so remove the screws so you can remove the exterior plate. Best of luck. Hope this works!
Nov 18, 2008 | Hardware & Accessories
Top Knobs M826 Door Pull Logo
1,910 people viewed this question
Top Top Knobs Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Top Knobs Hardware and Accessory Expert? Answer questions, earn points and help others
