Question about Brother HL-2040 Laser Printer
Printer Paper light flashing constantly. Printing impossible and no jam. Powered down, reset, reboot, etc....and still nothing.
    President:
  • 2,072 Answers
One of two things.
1. When the jam occured there may have been a small piece of paper torn off on a sensor.
2. And I think this is more likley. One of the sensor actuators has fallen off or is stuck causing the sensor to think there is still paper in the machine.
Take your time and examine the paper path carefully.
The actuators are black plastic pieces about an inch long hanging down into the paper path.
Posted on Jan 11, 2008
  • Rick Kasper Jan 11, 2008
    If those are not the problem, then sounds like a paper path sensor or switch has failed.
    Something it signling the main board that there is a piece of paper in the path. whether there is or not.
    most of the time an actuator falls off or is stuck.
    If you know those are present and moving freely, then a paper past sensor has failed.
    Good Luck. Those problems can make you crazy at times.
6ya staff
SOURCE:
This printer keeps displaying 'paper jam' every time it loads a sheet of paper to print. There is no paper jam & I have rebooted it many times to no avail.
One of the reasons why such error flashes is because the paper or media your are using might not be suitable for the printer. Always check on your paper preference before printing.
Oct 22, 2012 | Brother MFC-3240C All-In-One InkJet...
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
Kyocera FS 1020D
You might be out of toner.
Jul 22, 2009 | Office Equipment & Supplies
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Reset button constantly flashing and wont reset!
Hi Cressy
1.Power off the printer, then Unplug the power cable from back of printer and from wall outlet.
2.Press and hold ON button for 30 seconds
3.Now plugin and check the printer
Thanks
Riz
Jan 06, 2009 | HP DeskJet 970cxi InkJet Printer
E appears on my printer
why dont u contact cannon abt r problem i can not think of anyhing but hte cannon printers is faulty.........
Oct 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Brother HL-2040 Laser Printer Logo
236 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
