SOURCE: Droped Camera Broke the lock
Happy looking if you cant find it than i suggest u do plastic solder
take a small piece of hard plastic heat up the solder try to put the hard plastic at the place where the catcher had been and try to melt this plastic at its place
try hands on practice first for perfection
SOURCE: battery door clip on Dimage 7 5.0 mega pixels
try too fine a battery container which can hold your batteries and contact it too the camera by the external power plug.
It's an solution if you don't find a battery door.
You may also use a car battery of 6 volt by this system.
SOURCE: My Dimage X31 Camera does not turn on even with new batteries.
Make sure that you have them installed the correct way +/- and also check that the old batteries didn't leak and cause corrosion on the battery connection tabs.
SOURCE: need battery door part for Konica Minolta Dimage
e bahttp://cgi.ebay.com/NEW-KONICA-MINOLTA-Z6-BATTERY-COVER-SILVER-OR-BLACK_W0QQitemZ320433162573QQcmdZViewItemQQptZDigital_Camera_Accessories?hash=item4a9b4e094dy -24.99 at this site-
SOURCE: broken battery door
You can order a new door from http://uscamera.com/1min038.htm and put it on yourself.
