Question about Refrigerators
My in-door icemaker is not getting water from valve
    President:
  • 3,433 Answers
Make sure the ice tray is engaged. The water valve is tripped by the tray position and timed.
Posted on Nov 19, 2009
ghappliances
  • 126 Answers
SOURCE: Icemaker is not working, There
THERE ARE TWO VALVES LOCATED AT THE REAR OF THE APPLIANCE ONE FOR THE WATER AND ONE FOR THE ICE.I TAKE IT THAT THE WATER DISPENSER IS WORKING OK AS YOU HAVE NOT MENTIONED THAT ITS ALSO GIVING YOU A PROBLEM.I FIND IT VERY STRANGE THAT MAYTAG TECHNICIANS CANNOT PICK UP THE FAULT IF YOU STILL HAVE NO JOY I SUGGEST YOU GO TO HIGHER MANAGMENT AND GET IT RESOLVED.BUT TRY AND LOCATE THE VALVE AND SEE IF THEY BOTH WORKING.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 1122 Answers
SOURCE: Ice maker not getting water from water valve
you will need to replace the water inlet valve on the lower back of frig.easy,let me know how you do-mike
Posted on Oct 17, 2008
  • 218 Answers
SOURCE: Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
The prime suspect would be the solenoid valve. Check it for continuity with an ohmeter (after unplugging the fridge and disconnecting the coil, of course). If that's okay, then you might have a bad switch in the icemaker itself, or the supply line might be frozen. I'm betting on the solenoid. Good luck with the fix!
Posted on Jan 27, 2009
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
ginko
  • 19396 Answers
SOURCE: no water to door or icemaker on KSSS48DBW00
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
GE Side by Side Refrigerator model GSS25jfpa cc. No water to icemaker. Replaced the ice maker and the dual solenoid water valves. Still no water to ice maker? Water to door works fine.
if you can reverse the solenoid valve wire connections,then use the door water fill to activate this valve,but not long as it will overfill the icemaker,this will certify that theres water getting up to the icemaker,then it could be the maker itself not activating the icemakers water valve assy to fill the maker
Feb 01, 2013 | GE Refrigerators
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
I have two door refrigerator no frost but the unit could not make ice it has lesser cold output may i know whats the problem on this?
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
Aug 01, 2011 | Whirlpool Refrigerators
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
Icemaker does not work
if the ice maker cycles but is not getting water check the water supply valve that supplies the water to the machine it split and sends water to the door and the ice maker that side of the valve that goes to the ice maker could be bad you can test it with a 120 volt line cord plugged in the wall plug to that side of the water valve if it works with the hose disconnected it may be a blockage or frozen line to the ice maker
Apr 09, 2010 | Refrigerators
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is no water to my ice maker
there are three things that can cause this #1 icemaker #2 water valve #3 door eye that reads over ice bucket in door, these are a but difficult to narrow down cause but you can do it.Move unit away from wall and remove cover from bottom, the water valve is a three part component < one supply and two output > the two front vales have electrical plugs if you reverse them and operate door water the icemaker valve will operate putting water in icemaker < door has to be closed > If it does then water valve is good < replace wires to original places> if it is ok then the next step is to fill icemaker about a third full with water and wait < if it produces ice and drops it into the bucket then it is cycling as it should,<if ice stays in icemaker and does not drop in bucket then the icemaker has failed.If you do these two steps and find no failure,<both work> replace sensor that reads bucket level,<red light on right with on and off switch and opposing side pick up,> it is a kit and is easy. If you follow these steps you will find problem and get it fixed.
Mar 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
