Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
DCAC40A4 power converter failure
I removed the DCAC40A4 power converter from my Optiquest (ViewSonic) Q9 Model No. VS11201 LCD monitor. I was looking for a bad capacitor like so many mention but didn't find any bad. Then I noticed one of the two blue capacitors on the high voltage side is splitout on its side. I want to try and replace it but the info on the capacitor makes no sense
F .33J
PMD 250V
The period (.) in front of the 3 is actually positioned half way between the top and bottom of the 3. I have tried looking up this part but cannot find it anywhere. Can you help me identify this part?
  • sarnold4 Mar 14, 2010
    Just measured mine and sure enough mine is shorted also! I had replaced the split capacitor but the monitor still didn't light up. Now going to replace the diode and see what happens. Looks like a R240 UPM.
This is too funny. I have a Norwood lcd monitor with the same problem. It has the same exact board. I started to troble shoot and it is pretty tough without schmatics but there is a diode (d301) that I am getting a dead short across.
Posted on Mar 13, 2010
    Sergeant:
  • 226 Answers
I think this is a dipped .33 uf or 3300pf 250v cap. I thought tantalum, but none are available at 250v, so I think it is ceramic.
http://www.badcaps.net/ has a forum and a section for computer displays. There is a recent post on a viewsonic there.
digikey.com has low cost/order shipping fees, mouser.com has parts too.
tom
Posted on Dec 30, 2009
When you open up one of these you are best off replacing ALL the capacitors.
Posted on Apr 01, 2010
I found the same fail capacitor on my DCAC40A4 board. I replaced a good one but the problem is still existed, the power LED is blinking. Do you have any recommendation for this problem?
Posted on Mar 07, 2010
  • hclhcl Mar 14, 2010
    My diode look likes short but it is OK after I removed it from the PCB. I think there is something damage and has not been found yet.
Viewsonic optiquest flat panel lcd monitor power light flashes on and off with a popping niose
Look for bad caps with bulging/leaking tops as shown here:
http://s807.photobucket.com/albums/yy352/budm/OPTIQUEST/Optiquest%20Q9B/
Very common problem in all LCD monitors as you can see in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 26, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
NO POWER TO THE MONITOR
This is usually caused by a failure of the power supply board because of capacitor failure. The board is easily repairable if you can do a little soldering. Here is a a link to a page that shows how to open the monitor, remove the power supply board and what needs to be replaced to repair the unit.
http://www.ccl-la.com/blog/index.php/how-to-repair-a-optiquest-q19wb-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 14, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
At start up my Q9 the power light turns green and then starts to blink making a clicking noise. Sometimes it turns on sometimes it doesn't.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed OPTIQUEST monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Feb 25, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Optiquest vs11201 monitor not above 640x480 resolution
You need to download the driver from DELL for your video card, my 3000 use video driver R79733.EXE.
You may have virus in your computer if you cannot update the drivers, sometime it is better to start from clean drive to help get rid of stuff that get installed into the computer.
Apr 12, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
My Monitor just stopped working. No pop, no fade, just dead. Oh, sorry it is an optiquest Q19wb says manufactured in 10/2006. bought 1.5 years ago at best buy. Worth trying to fix or dump it??
Optiquest is the Viewsonic low end products. You can take it apart and look inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
When I power on my viewsonic monitor it flickers and the screen doesn't come on. It is a 19" Optiquest model number VS11201 that I have had for 2 years.
After 2 years, more likely the caps will be bad by now, worst case will be bad lamps, open it up and look inside for caps with bulging top first, see example of failed monitors due to bad caps/lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 13, 2010 | ViewSonic OptiQuest Monitor
Monitor doesnt turn on
From your description, it sounds like the internal 5 Amp cartridge fuse is open. Will need to open the housing and inspect the fuse for failure. If located and failed, replace it and energize the monitor.
If the fuse fails immediately, you have a High Voltage power supply short and the monitor is scrap. It will cost more to replace the power supply/transformer than the monitor is worth.
Hope this provides some useful information.
-Jim
Oct 17, 2009 | ViewSonic OptiQuest Monitor
Q19wb Monitor Replacement Part Numbers Needed
Look on eBay for "Optiquest Q19wb repair" or "Optiquest Q19wb power"
This is a common failure mode. You can either buy a set of capacitors and solder them in, or buy a replacement power supply board if you cannot solder.
One eBay seller notes the power board as an ILPI-025, which is common among the following models:
Power Board ILPI-025 For LG W1934S & Viewsonic VG1930WM & Optiquest Q19WB & Acer AL1916W Ab etc
Model:ILPI-025 REV:E 79069140
May 29, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
1,116 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
