Question about Logitech Harmony 880 LCD Remote Control
My 880 will not charge I used this 2 years ago and it worked The remote still holds the old settings I now want yo use it but the unit said battery low recharge. I tried to charge it but it would not charge, I replaced the battery with like for like and again tried to charge but again no charge. I replaced the battery charger with new charger and cleaned the charge points. the charger blue light is on and the remote goes through the test then says press->. I leave on charge for 16 hrs and still the battery is flat I have tested the charger output and the remote input circuits and both have 8.9vlts output and input. I am at a loss could there be a fault within the remote? If you know of anyone who can investigate this problem let me know
  • 4 Answers
There is a trick with these remotes. Take a tiny piece of paper and
wedge it in between the battery and the side of the battery compartment
opposite the battery contacts when you insert battery.
This will apply more pressure between battery contacts and remote.
Now your harmony should properly charge up overnight.
Had the same problem with mine and the paper trick fixed it.
Was even able to use the old battery again.
Has something to do with the three contacts on the battery.
All 3 need to make good contact.
Posted on Nov 19, 2009
Testimonial: "didn't work with new replacement bat all that happened was the test process and press -> symbol and then I get a red circled ? in the top right"
Check this solution out: http://dan.langille.org/2005/11/27/harmony-880-remote-battery-problems/ - I thought it was the metal contact points, but that was entirely wrong - it was the battery compartment. the remote will WORK, BUT NOT CHARGE if the battery isn't pushed into the interior contacts.
Posted on Dec 27, 2009
    Novelist:
  • 101 Answers
I wouldnt recommend putting pressure on the remote to charge. If the battery contacts are not touching with no pressure this is a hardware issue and you do need the remote replaced. Also, they dont recommend using paper to wedge between the batteries in the remote. All of the things that have been recommended are used for toubleshooting, not fixing the issue. Anything like this can void your Warranty. If your not under warranty, e-mail in, they will have a solution for this. Please try the following:
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
ANSWER:
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
ANSWER:
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
ANSWER:
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
ANSWER:
Posted on Jan 25, 2010
Got a preowned 2004 318i executive series E46 facelifted two months ago, comes with 2 sets of ignition key with remote on fob. Suddenly, 1 key that can operate the keyless entry will not start the engine....
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 2 [2]. Press lock button Fig. 2 [1] briefly 3 times within 10 seconds keeping unlock button [2] depressed. Release unlock button Fig. 2 [2]. Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work.
NOTE: A maximum of 4 keys can be programmed. Carry out programming procedure for each key within 30 seconds.
Aug 30, 2010 | 2006 BMW 3 Series
Won't charge in cradle, shows slide show then goes dark. has power to remote won't charge know matter long it sit on it
The early 880's had problems with the charging circuit. For a while Harmony was replacing these units even outside the waranty period. Not sure if they are doing this anymore. However your remote is recognizing that it is in the craddle because the slide show starts which means the charging circuit in the remote is not passing power onto the battery or the battery is not making a good connection inside the remote. I would pull the battery and clean the little contacts in the remote and the contact pads on the battery. If you have a volt meter I would pull the battery and check voltage. You should see around 4 VDC on the 2 outside copper pads if it is charged. If it is charged and the remote is not working then its time for a new remote. If the battery is dead then it is likley the typical charging problem of the 880 is causing the failure. Hopefully cleaning the contacts both inside the remote and in the charging craddle will solve the problem. Use alcohol and a q-tip to clean all of the contacts.
Good Luck
Apr 01, 2010 | Logitech Harmony 880 LCD Remote Control
2 year old BB Curve 8330 over heats
its the battery ........the more you charge them the less they hold a charge ...if yo look at your battery it is probably swollen from charging
Mar 09, 2010 | AT&T Blackberry Curve 8300 Smartphone
Garmin 260 now failing to charge and shuts itself down
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Jul 24, 2009 | Garmin nuvi 205 GPS Receiver
Universal TV remote not charging properly
I have same problem, try making 2 balls of foil and put inbetween charger cradle and remote.
Jan 08, 2009 | Universal Remote Control Harmony 880...
Remote needs ABSOLUTE DIRECT Line of sight
If the battery was out for that long, it's likely that the remote lost its programming.  Did you try reattaching it to the website after the battery had recharged, so that the programming could be restored?
Dec 23, 2008 | Logitech Harmony 880 LCD Remote Control
880 won't work unless I hold it within two inches of tv
See here for a guide on replacing the IR LEDs in this remote:
Link
Jan 04, 2008 | Logitech Harmony 880 LCD Remote Control
Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Nov 15, 2007 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 880 LCD Remote Control Logo
472 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
