Question about Vizio GV42L 42 in. LCD Television
My vizio remote control stop working changed batteries and it still doesnt work
    President:
  • Vizio Master
  • 1,779 Answers
Take the remote to a Best Buy in your area ( if you have one ) an see if it works on another Vizio set. If it does, then your set will have have to go in for repair.
Posted on Nov 19, 2009
Remmote stop to work
If a battery change does not restore operation, it is likely that the remote has failed. As for finding a code, you have it backwards. The codes are stored in the remote. If you obtain a replacement universal remote, follow the directions to find a code for your Vizio TV.
Apr 07, 2014 | Vizio VS420LF1A TV
Vizio tv601i remote stop working
if the vizio tvs are of different model numbers but same type name they may not work with same remote as they say, product subject to change without prior notification.....solution.....get the exact remote for that particular vizio model
Jul 20, 2013 | Televison & Video
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
My vizio remote control does not work with my tv what can I do
If it came with the TV, then there might be a problem. First check if you have the batteries in the right position, we all make small mistakes. If it doesnt work then there might be a problem with the remote, shake it kinda so you can hear if anythings broken. If it doesnt work return it within your time period and pick up another, because it could also be the TV IR. ;)
Mar 04, 2011 | Vizio VO22L 22 in. LCD TV
My remote will not work
Dessasembly the remote control:
1.Clean,use the izopropilic alcool or 75%alcool or finest wisky the remote taste rubber pad.
2.Assembly the remote control,change the batteries(see the polarity).
3.Near on functional in the FM or MW radio (the distance to remote and speakerphone max.10cm) press any buttons to the remote control.If you can hear the emitent signal in the speakerphone ,the remote is work.
4.Try the remote to TV.If work is OK,if not change the infra LED.
The solutions is work 100%,I tested 25 years ago.
Sep 07, 2009 | Vizio VX32L Television
Remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
Apr 25, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
259 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
