Question about Microsoft Windows 98 for PC
System Code Error 87
In XP OS system,My Exe is working Fine.But when i run the same Exe in Windows 98 OS System,it is giving an error 'Exception EOS Error in module Application.Exe At 000F 2FA system code Error 87 Parameter is incorrect'.
Give the solution as soon as possible.
  • romanchmelar Apr 04, 2008
    STOP 0x00000050 (8xe5189f8, 0x0000000, 0xf733ef3e, 0x00000002)
    setup dd.sys - adres f753ef3ebhse at f751a000, datestamp 3d6dd67f
  • Anonymous Mar 20, 2014
    when I unplug USB then I get this message "Application Index.exe encountered a serious error and must shut down" and display freeze but sistem "radio" works.
    Any solution..?
    Master:
  • 788 Answers
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
Posted on Jan 11, 2008
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Windows 98 won't boot up
Can you run Win98 in Safe Mode? Just tap F8-F10 or Del or Esc on booting (It's different buttons on different machines) to enter Advanced Settings and run Win98 in Safe Mode. You can get access to your files, and maybe even System Restore back to a point before you had the problem?
Worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Microsoft Windows XP Home Edition
PCV-RX463DS Sony Vaio Sound
  • http://www.drivershq.com/Drivers/Sony/PCV-RX/PCV-RX463DS/9818/10169/10184/Drivers.aspx
  • download the utility.
  • tis should fix it.
Dec 10, 2008 | Sony VAIO PCV-RX463DS PC Desktop
System Error. Code : 87. Parameter is Incorrect.". Please give me solution for this
When I want to connect a software ,which connect to Database through ODBC display the messageV"System Error. Code : 87. Parameter is Incorrect.". Please advice solution
Mar 29, 2008 | Microsoft Windows 98 for PC
Problem starting windows98
My suggestion is to follow up with the rest of us and install XP.. XP OS is so much more stable than 98... Upgrade a little bit on the hardware-front, and get XP...
Feb 08, 2008 | Computers & Internet
Microsoft Windows 98 for PC Logo
506 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
