Question about Boating
I have a johnson 50 hp outboard when travelling in excess of 5 knots the prop stops turning and motor revs high.
  • 677 Answers
In the hub of the propeller is a rubber bush that stops damage to the shafts and g/box if something is struck with the prop.These bushes do give way and are repairable.See your local boat shop or look for a specialist propeller shop.Probably the latter as the boat shops sends the props to them anyway.Its called the propeller hub bush or just the prop bush.Just take the prop into them and all will be good.Hope this helps you
Posted on Nov 20, 2009
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
I have a 1984 glstron boat wit a 70 hp motor with a 13x15 pitch prop. and have to play with the power trm to get boat to plane out. How do I know if I have the right pitch prop.?
You do not tell us the size of your boat. I sounds as if you have the motor set too high in the transom. Does the motor just rev up and not move the boat or does it lug down and not seem to have enough power? More info, better ideas.
Apr 19, 2013 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Have new tohatsu outboard that runs fine but wont rev out over 4500 rpm
I just looked at 7 different sites and they are saying Max RPM is between 4,500 - 5,050... How accurate is your Gauge?
Prop Pitch will greatly effect MAX RPM.
Apr 05, 2013 | Sierra International 18-6431 Marine...
My 1988 johnson outboard 50 hp motor dies off when given full throttle
Any fuel filters? If the fuel line is old I would replace it due to the ethanol in gas. If not that then clean the carburater, high speed jet may be clogged.
Aug 23, 2010 | Raymarine Linear Feedback Unit For...
Help. recently cavitated my 140 hp 1989 mercury outboard motor at high speed.I Removed the lower unit several times but only goes in forward about 5mph. Please help Tx jack
Not really sure what is wrong.Do all the gears work?Does the motor rev properly.Did you change the height of the motor.If the motor etc. are all ok and the motor cavitated at high speed,you may have spun the bush in the propeller hub.The symtoms are,everything works ok but the boat can rev but will have very little forward propulsion.If this is it,the prop needs to come off and taken to be rebushed.The bush stops major damage to the g/box if the prop strikes something.Hope this helps
Sep 07, 2009 | RTO Outboard Motor Bass Fishing Boat Rod...
35hp Johnson evinrude outboard not running at full potential
Hi, did you buy your engine used? Sounds like your gonna have to get the carb or carbs cleaned. Its possible you could have a stopped up fuel filter, or not enough spark but i am guessing its gonna be the carbs. They got some gunk in em i bet. Probably old fuel turned to gunk from setting up. I had the same problem on my 40 horse.
Aug 22, 2009 | Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Jun 30, 2009 | Sport & Outdoor - Others
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Boating Logo
264 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
