Question about CyberPower 485VA UPS Backup (BE485) UPS System
My tv cable box and radio are connected to my cyberpower 485. quite often it shuts off my cable box and tv and beeps, the radio does not shut off. This time when I pressed the siver button it tries to reboot the cable box but shuts off again and starts to beeps
    Sergeant:
  • 295 Answers
It sounds like it's either at the age where the batteries need to be replaced or there is a problem with a component 'Capacitor or transistor' on it.
Is it still under warranty. If not - if you pull the batteries out of it you may be able to find some replacement ones on line. Place the part # of the battery in a search engine.
A Good place to try is CyberPower's website also.
Blessings,
A/V Guy
Posted on Nov 19, 2009
Motorola DCX3200-M beeping after rehooking
Hi Russell,
Your query has been posted on the 2-way radio forum.
please post on the TV forum on this site.
Regards, Peter
Dec 11, 2012 | Radio Communications
Cyberpower 425 va When the device kicked in during
You can change that. It is designed to alart you during a power outtage. That way you will have time to shut down your servers. It will alway alarm during a power outage. But check to make sure your batteries are in good condition
Sep 09, 2011 | CyberPower Intelligent LCD CP825LCD 825 VA...
It is making a beeping sound non stop
I looked for quite a while and I couldn't find anywhere that told me what the beep is... My best guess would be the batteries are bad and need to be replaced.
Use the like below and CyberPower will help you with the problem.
http://www.cyberpowersystems.com/support/online-support/ups.html
I hope this helps you.
John
Feb 14, 2011 | CyberPower (R) CP825AVRLCD Uninterruptible...
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My 485VA back up system beeps after I have a few things plugged into it. Does the beeping mean the battery is bad?
Try only the computer and monitor - it may be overloaded, 485VA is around 400W only, so it won't accomodate much more than a standard computer + monitor.
Especially a laser printer is very power consuming and should not be connected to any UPS.
Nov 28, 2009 | CyberPower 485VA UPS Backup (BE485) UPS...
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
My volume just shut down on me. how do I turn it
go into menu of tv make sure speakers are turned on--if you are using a cable box turn the cable box volume up-let me know if this helps you-djstvrepair@comcast.net
Sep 04, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
585avr isn't working w/vista OS,
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @ http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
Oct 31, 2008 | CyberPower Office Power 585AVR...
RCA DRD485RG Direct TV
verify that the problem box is not looking at a "favorite" list
Jan 11, 2008 | RCA DRD485RG DirecTV DTV Receiver
The TV and Cable box both continue to shut down; Please Help!!!
Do you mean that the TV shuts off and the cable box also shuts off? Is the TV plugged into the back of the cable box? This sounds to me as if the cable box is defective and the TV is plugged into the cable box instead of the power strip. To prove whether or not the cable box is defective, plug the cable directly into the TV, plug the TV directly into the wall outlet and watch one of the lower channels. If the TV acts up and shuts off, have the TV serviced. If the TV plays fine, replace the cable box.
Jul 02, 2007 | Daewoo DTQ-29S1FCN 27" TV
CyberPower 485VA UPS Backup (BE485) UPS System Logo
182 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
