Question about Intel S5000XVN Motherboard
Missing Processor Cores
Hello Experts
My system consist of 2 units Dual Core Xeon's Running at 3.0Ghz, 2x2Gb Ram, Dual DVI 512Mb PCIe x16, 6x Sata II Drives, Huge 1010 Wat Power Supply.
System boots fine, all 8 Cores (4 physical + 4 Hyper Treading) are running well, even under extreme stress like heavy video rendering for long periods no visible problems.
The system can run for 1 hour or 3 days & nights in a row, after it runs warm / hot, and is rebooted only 4 cores show up in the system (4 are gone)
The bios shows various errors on processor #2 but not consistant same number, it varies but alway processor # 2.
Even after the processor #1 and #2 are physicly swithed the system only shows 4 cores.
When system is used with either one processor is shows no problem, always 4 cores, even after running warm / hot and rebooted.
After the system is shut off and allowed to cool for about 1 hour is runs again on all 8 cores, for hours or days, as long there is NO reboot.
This problem is driving me nuts, I have changed to other Display cards, Ram has been changed, a power conditioner has been bought, a Huge APC smart ups to eliminate power supply problems.
Eventually the Motherboard has been exchanged, still the same problem.
I did run the processors one at the time and also swapped their physical position.
I'm lost for idea's and I need help for the first time building a new system.
Any suggestion's from the experts ?
Best regards Tony Dekkers.
  • SoundFreak Jan 11, 2008
    It's build in a 4U Extended Server casing c/w with 1x 12 Inch fan to cool the 5 Units Video / Data Drives, 1x6 Inch fan to cool the boot drive, this all located at the front.
    Then of course the 2x Xeon have their own intel copper heat sink c/w 2x fan bios controlled (set to high performance)
    The power supply has 3x 6 Inch fans, the back of the casing has 2x 6 Inch fans, more than enough to keep steady airflow through the system.
    My only concern are the 2 chipset heat sinks and the System ram which to run rather hot (no fan yet, planning to) and the display adapter also without fan.
    My system operates in Asia on the island of borneo, therefore the temperature is a bit high, 33 in day, 28 Degrees at night, thats why all fans are running full speed except the processor fans, they are bios controlled and go to almost full speed every now and then while rendering video, otherwise (normal operation - no heavy rendering) they run pretty silent.
Thanks it guru,
I am currently in contact with Intel (finally the respond) and the possibility of processor exchange / upgrade is being discussed.
Will post more info when it becomes available...............
Posted on Nov 17, 2008
If you are runnung Vista HP 32 bit (maybe Ultimate also), the problem lies with Vista. I had the same problem. I installed Vista Ultimate 64 bit and presto! Problem solved.
Posted on Nov 14, 2008
Indeed I think I have to study all the cooling solutions that are available to solve my problem.
I also send a mail to Intel support, lets see how good their support is for server / work staions, but as a end user I don't even expect a reply, time will tell.
As I live on a Island and the computer shops over here only cary very basic stuff I need to get all my info from the web, and I have burned my wallet more than one before, so I will take my time before ordering anything.
If users with similar Xeon sytem changed their coolers succesfully i would appriciate it if they would post their product recommendation here.
Posted on Jan 12, 2008
    Problem Solver:
  • 19 Answers
Nice system, what kind of cooling do you have in there? How many fans etc...
Posted on Jan 11, 2008
  • Douglas Green Jan 11, 2008
    from some of the reviews i have read them heatsinks are really cheap, only a chunk of copper with weak fins and the fan is loud. I bet this is the problem here. I would replace them heatsinks with a better aftermarket heatsink make sure that when you replace them you fully remove the adhesive using (90% ispropyl rubbing alcohol) from the processor as best as possible and use a better adhesive. But do this with caution because you can mess up the processor if removed incorrectly.
Laptop doesnt boot when multi core processing is enabled
By multi core I assume you mean when enabling all of the true processor cores. In your laptop's case it's a Dual Core processor which means there are only 2 phyiscal cores and does not contain HyperThreading Technology (HT Technology) which enables "Virtual processor cores"
Could be caused by a couple of things:
1. Your processor doesn't support multi-core processing which is a possibility given there is no HT technology for your CPU. In which case there is nothing to fix. Even though the BIOS may have this option. You can check to see if both cores are enabled when you have multi-core processing disabled; In windows right click on your taskbar and click on "Task Manager" Click on the performance tab. You will want to count the number of processor displays you see. Refer to this to see what I mean:
The reason I have 8 CPU displays is because I'm running an i7-3820 CPU which supports HT Technology; So I have 4 physical processors cores and 4 virtual processors cores (created by HT Technology architecture)
2. You are running Core2Duo CPU with dual physical processors and have disabled 1 of the 2 cores because your laptop won't boot. This sounds more like you need to update the BIOS on the motherboard or maybe a bad CPU might be the cause as well.
Hope this helps.
Sep 12, 2013 | Toshiba Satellite M505-S4945 PC Notebook
Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Oct 22, 2012 | HP Compaq SR5702F PC Desktop
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
Jul 08, 2011 | Intel DG31PR Motherboard
Image flickring when i played gta san andreas?
hello jaymarque, hi, try reducing the resolution, if not you should upgrade your onboard RAM around to 1gigabyte ram, switch your processor to Dual core 2.0GHz and or upgrade/change your AGP to a ram up to 512mb
Nov 20, 2010 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Aug 03, 2009 | Dell (E210882) Motherboard
I am from INDIA... i want to buy i IBM
Hi Friend,
Check below the model numbers of the intel dual core mother boards avaliable and the
address where u can buy it in Chennai,
1.Intel Atom 330 Dual Core (2x 1.6Ghz)
a.Intel D945GCLF2 mini-ITX
Features are:
  • Dual Core Atom CPU
  • TV-Out (S-Video)
  • 4x Rear USB 2.0
  • VGA, Serial and Parallel
  • 1x DDR2 533/667 RAM
  • 1 x Gbit LAN
  • Realtek High Definition Audio
  • Power: 24 Pin ATX, P4-connector
  • RoHS compliant
b.ECS P945GC
Feature are:
  • custom design board using mini-DTX form factor up to 170×170mm.
  • Intel 945GC and ICH7 chipset Intel Atom 330 CPU dual-core 1.6 GHz, 2×512KB (1MB) of L2 cache
  • FSB 533MHz system bus support up to 1×2GB (DDR2 533/400)
  • Integrated Intel Graphics Media Accelerator 950 ( GMA950 )
  • 2 X SATAII and 1 x IDE channel (for 2 IDE devices)
  • VIA VT1708B 6-channel High Definition audio CODEC
  • 10/100 Fast Ethernet LAN using ATHEROS AR8012 10/100 Mbps PHY
C.Jetway NC92-330-LF
Features are:
  • INTEL®945GC + ICH7 Chipset
  • Support INTEL®Atom Dual-Core 330 CPU
  • Built-in INTEL®GMA 950 Graphics Core
  • Supports 1x Gigabit LAN
  • Integrated ALC662 HD Audio CODEC with 6-CH
  • ITX Form Factor(170mm x 170mm)
  • Support Daughter board Expansion
D.Foxconn 45CSX / 45CTD (soon to be release)
Features are:
  • Intel® AtomTM dual-core 330 processor mounted on board
  • 533 MHz (FSB)
  • DDR2 533 MHz x 1 DIMM, Max. 2GB
  • 1* PCI
  • 2* SATA II
  • 5.1 channel HDA, Realtek® ALC662
  • 10/100M LAN, Realtek® RTL8100C
  • 6 USB 2.0 ports
These are available in India with Prices and best in India Industry
Intel Dual Core Price list in India
  • Intel E2140 Dual Core Processor - 2100/- Indian Rupee
  • Intel E2160 Dual Core Processor - 2450/- Indian rupee
  • Intel E2180 Dual Core Processor - 2800/- Indian Rupee
  • Intel E8500 Core 2 Duo Processor - 8200/- Indian Rupee
  • Intel 2200 Pentium Dual Core 2.2 GHZ -3400/- Indian Rupee
  • Intel E4600 Core 2 Duo Processor - 4990/- Indian Rupee
Address:88/150.Nelson Manikam Road,Dharma Tower Ground,Floor7&8,Choolaimedu,Chennai-94
Landmarks : Near Nungambakkam RailwayStation / Loyala College /Metha Nagar Bridge/Opposite to Bank of Baroda/Mobile Store/ Indian Terrain Ready made
Contact Number:98402 72809
For future assistance kindly contact fixya
Jun 26, 2009 | Abit AS8 Motherboard
Screen goes blank after 5 minutes (tyan tempest s5380)
Try booting without expansion cards. Watch your processor temperature carefully. I guess you have problems with processor. Try another processor if you have around. Keep posting.
Feb 21, 2009 | Tyan Tempest i5000PX (S5380) (S5380G2NR)...
Printer stop printing ink
If you can't even get ink to come out for a nozzle check, there are two different things you can try. Update the Epson Firmware, or you'll have to change out the motherboard.
Feb 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Intel S5000XVN Motherboard Logo
117 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
