Question about Xerox CopyCentre C20 Black and White Copier
Copycentre c20 has open heat error message. How do I replace fuser unit?
  • 82 Answers
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Posted on Nov 29, 2009
Workcenter pe 16 open heat error
Bad Fuser. Google a business called The Parts Drop to order.
It is not difficult to replace. Remove the back cover, 4 phillips screws pull out slide the new one in.
I would remove the fuser first though. And check the plastic in the ends of the fuser. If they are melted, then the power supply has failed and you will have to replace both the fuser and power supply. If the fuser looks normal no plastic on the end of the rolls melted, then just replace the fuser.
Mar 12, 2011 | Xerox CopyCentre C20 Black and White...
Open heat error...can I replace on my own?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 13, 2010 | Xerox CopyCentre C20 Black and White...
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
Had a paper jam, cleared jam. Had made probably 30 copies prior to this happening and then the copier doesn't work - open heat error
You probably had an overheating condition that opened the thermostat of the fuser.You'll have to replace the fuser assembly because it is not a resetable thermostat.But before you do that, check the wiring (two smal white wires exitin from the fuser) for an open cirquit or a bad connection to the terminals.
May 27, 2010 | Xerox CopyCentre C20 Black and White...
Xerox copycenter c20 displaying "open heat error" and won't function.
Bad fuser. There is a mesh type heater in the heat roll that goes bad.
The fuser is in the right side door, at the top, Has the Caution Hot labels on it,
You remove the 4 silver phillips screws and slide it out.
Google a business called " the parts drop. They will have it and they are excellent to deal with, Call and talk with Brit or Elaine. Good people to do business with,
Feb 02, 2010 | Xerox CopyCentre C20 Black and White...
Low heat error display
You will need to replace the fuser. There is a fillimant type heater in the fuser roller that goes bad.
Google a business called "The Parts Drop".
They will have what you need. It is very easy to change. All you need is a phillips screw driver.
You open the right side door as if you were removing a jam. You will see 4 silver phillips screws, one with a thin plastic cover . Remove those 4 screws, unplug the one plug, slide the new one in and plug it in. It will warm up and be ready. I looked it up, the fuser is $160 and should be good for 40 thousand pages or more.
Dec 29, 2009 | Xerox CopyCentre C20 Black and White...
Open heat error
if you meant to write over heat error, it should go away after the fuser cools down. if it continues to happen, the fuser unit will need to be repaired or replaced
Nov 02, 2009 | Xerox CopyCentre C20 Black and White...
What is open heat errot
One of two things, both will require a fuser replacement.
Either the over hear thermostat has open, or and most likely the heating element built into the heat roller has failed. Normally the heating element burns out and displays that message, I have not found that roller assembly spared, and even if you try and swap one from a used fuser to new, they are really dificult to change because of the spring end contacts.
In simple terms, replace the fuser and you will fix the problem.
Mar 28, 2009 | Xerox CopyCentre C20 Black and White...
OPEN HEAT ERROR
hi im jules_09,does the machine warms up?if not reset the error code in the program.if the is still there check the termistor,heating lamp and termalfuse one of those components are deffective.test it with a tester
Nov 02, 2007 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
528 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
