Question about NetGear WGR614 Wireless Router
Am tryin to go wireless on my wii, the other nite i was on but today its not workin
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
You can go with the following steps to configure the WII with Netgear WGR614:-
1)First and foremost you should be aware of the wireless settings you have on the router i.e ssid(broadcast name) and the type of security(wep or wpa-psk) and the password for that.
2)On the X-Box get into the setting's menu where you will find and option for wireless set up and then scan for the network , it will automatically scan your ssid , select that and will ask for the password enter that and you will be connected.
3)Go for the connection test if it's successful then play games with it and if not then follow these procedure:-
a)Get any computer which has the internet access to it , Open the IE page and in the address bar type http://192.168.1.1 or http://routerlogin.net/ , a small window will prompt up asking for user name and password which is admin and password respectively.
b)You will be navigated to router administrator page , you will have a blue/purple column on the left hand side which has the different setting options in there.
c)Under the title Advanced you will find a subtitle WAN set up left click on that option and the page will appear in the middle of the screen.
d)Under WAN set up there is an icon for DMZ server tick that box and then enter the ip address:-192.168.1.20 and left click on apply at the bottom and the page will get refreshed.
e)Go back to X-box live and under wireless set up select manual setting's , it will ask to enter the following information:-
security type(wep/wpa-psk) and password to it
subnet mask:-255.255.255.0
default gateway:-192.168.1.1
Primary DNS:-192.168.1.1
Secondary DNS:-leave that blank and apply the setting's
f)Go for the connection test and it will have the successful connection.
Posted on Nov 20, 2009
Wii will not conect to the internet today, we have not had a problem before today. When I test it it shows an error code of 52030.
The following information was taken directly from Nintendo's website about error code 52030. I have included a link at the bottom directly to the page from which I got this information. If you click the link, there will be a step by step guide on fixing the error:
Error 52030
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=en_US&action2.x=29&action2.y=19
Apr 07, 2011 | Nintendo Wii Console
I'm tryin to get into my Netflix but error code 51330 keeps poping up and denying me access how do i go about tryin to fix this
This code means a network connection cannot be established. Check you connection settings to make sure you are connected to the internet. If you are connected your router may be having some problems establishing a connection with your wii. You may have to reset your router to factory settings you will need to read your routers manual how to do so. Every router has a different way to reset it to factory settings it can be as simple as pressing a button behind the router or having to go into the software settings and doing it from there. If you reset it try to connect your wii to your router again by doing this: Step 1: Turn on Wii Step 2: Select the Wii button on the left side of main menu.
Step 3: Select "Wii Settings"
Step 4: Scroll until you see "Internet" and select it.
Step 5: Select "Connection Settings"
Step 6: Search for an open connection by "Connection 3:None button"
Step 7: Select "Wireless Connection" and search for access point.
Step 8: Choose the access point desired from the list and save the settings.
Step 9: Test your connection. If successful you are connected to the internet if not go back and check your connection settings.
Let me know if you still have problems. Good Luck!
Feb 26, 2011 | Nintendo Wii Console
I am tryin to hook the enternet up to my wii
Let's get you connected!
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
      (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
  5. Click on "Wireless Connection" and then "Search for an Access Point."
      (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
      (If you're not sure which is yours, or you don't see any wireless networks, click here.)
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
        As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
    • The connection test was not successful - If the test was not successful, you will receive an error code.
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jan 26, 2011 | Nintendo Wii Console
My other half bought me a wii drumkit for my birthday today but can't get it to sync with my console. She was unaware that it is not a Nintendo make but a Harmonix although it is licensed by Nintendo. Can...
wll everthing is licensed by nintendo that is made for the aight? make sure ur wii remote is working and put ur wii remote in the drumkit . . . and if it still aint workin take the wii remote out and re sink it . . like press the two little red buttons . . the one on the wii and on the remot and if it still dont work then sorry due idk wut to tell u . . . hopefully i helped -eli . . . . . the coolest kid on da web
Mar 15, 2009 | Nintendo Rock Band for Wii
Guitar hero world tour for wii problems
try callibrating tv game go to options>callibrate
Dec 25, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Dodge caravan 98
Hay hun On a Caravan that Dont start it can be meny of things could be that your Distuter stoped workin on it most likely or it could be the Coil on it depends if it is tryin to start check on of them but if its not tryin at all Starter
Jun 25, 2008 | 1998 Dodge Caravan
Cant get may psp and my wii consoles to work
This is the password to your wireless network.
May 15, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear WGR614 Wireless Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
