Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
Dies at high speed - Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
  • 169 Answers
Most likely its just a simple carburetor adjustment. Find the adj needle labeled "h". Turn that screw counter clockwise 1/4 to a half turn out. This will richen the mixture and should run like a champ
Posted on Nov 20, 2009
Impacts of Vacuum Die Casting Technology on Aluminum Alloy Die Castings?
Aluminum alloy die casting is the casting process that injecting the high temperature molten aluminum alloy liquid into die cavity with high pressure and high speed for moulding. Features of this casting method are product precise forming and high production efficiency. However, the conventional die casting process is defective. Because the gas in the mold cavity cannot be eliminated effectively, the gas in the mold cavity cannot be eliminated effectively, and the inner parts of the casting can be left to form the defects of the pores, to make the mechanical property of the casting poor. In order to solve this problem, people use the method of vaccum pumping, that is, the gas in the cavity of the die casting can form a certain vacuum or negative pressure state, thereby reducing the inner hole defect of the casting.
Dec 21, 2016 | Cars & Trucks
Why is the ac cold but doesn't blow high
It's the armature, high speed fan motor or maybe the switch could b broken, I'll look at it, 9494545252
Apr 30, 2016 | 1995 Lexus ES 300
Small gas engine dies when choke full open
I have attached a diagnostic sheet to help you determine what is wrong.
Jan 21, 2014 | Weedeater 2 Speed Gas Blower FL1500LE ()
I have a Stihl 009 chain saw that I just rebuit the carb on and when it runs at high speed it does so only for a few seconds then dies. It will idle all day long. What could the problem be?
Have you replaced the fuel filter in the tank? it will idle as the engine is not calling for much fuel, however at full revs it calls for a greater amount of fuel, if that fuel is not available the saw dies.
Dec 29, 2012 | Garden
Idle speed harley davidson 2007
What DTC. P0505 is IAC. Sounds like an IAC problem. Colud also be an intake leake though so test for that also. Post a comment for more info or to advise further etc.
Sep 02, 2012 | Harley Davidson FXDWG Dyna Wide Glide...
Air conditioner blower only works on high speed
Blowing air at high speed only indicates that the fan controller is dying or the fan itself is dying. Have a mechanic check this out.
Jul 12, 2009 | 2003 Toyota Corolla
Homelite 2-cycle gas line-trimmer - It starts okay but when you hit the throttle it dies.
The high speed jet is either out of adjustment or it is plugged. There should be a screws with H (high speed) and L (low speed, idle) You could try to open the high speed adjustment on the carb or run your machine on partial choke if you have to.
Apr 17, 2009 | Craftsman 25cc Gas Line Trimmer
I have a Silver Eagle III leaf blower/vac. engine surges
Try turning the high speed adjustment screw counterclock wise a little at a time and see if that helps.
Mar 24, 2009 | Garden
Dies running wide open
Hi
Check the air and the gas filtetrs.Change the plug with a new one with the same heat range.Adjust the carb H and L.
High speed H=2 turns and low speed L=2 1/2 turns
best regards savumihai71
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
477 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
