Question about Biostar TForce4 SLI Motherboard
Issue powering on
I've had my computer running fine for a while, then all of a sudden it stopped turning on. All of the LED lights on the Mobo is off, except the ready to power on one (I believe it's the LED_5SB). Manual says the D1 and D2 LED's being off reads as a CPU/chipset error...this just happened one day when I went to turn it on. Any solutions?
  • 95 Answers
Replace the cpu or ram.
Posted on Jan 11, 2008
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Asrock N7AD-SLI Motherboard LED
The fans and indicators working for a sec would normally mean that your power supply is Ok. This flash of current must trigger a switch in the mobo to start the boot process. This is not happening. The RAM is a principal player here if it does not connect the memory to the processor nothing will happen. Assuming the RAM is correct and has worked faultlessly before, remove and clean the teeth with an eraser. This prob can also be caused by the VGA card not connecting. Usually alarms sound if your mobo speaker is connected but that depends on each mobo. These are basic steps that usually start machines that have been inactive for a time or have recently been exposed to high humidity. There could be other faults...............
Aug 28, 2012 | Asrock N7AD-SLI (4711140872940)...
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
Hi there. I have issue with this mobo regarded to pwrLED which is not ON even with the PSU plugged in. Actually what is happening is that as I turn ON the PSU main switch sometimes i get light from the...
In my experience you may need to replace the case but if you feel up to the challenge you can clean the contact headers on the MOBO for the PW LED and try reseting the CMOS for the bios.
Mar 20, 2017 | ASUS A7V266-C (A7V266-C W/A) Motherboard
Power supply problem
Hello
Im using the intel dg33bu board with an intel core 2 ,3ghz.
When i built the pc i upgraded to a 450watt power supply.
Try a 450watt supply.Consult intel on the proper specs.
Apr 15, 2010 | Intel DG31PR Motherboard
Dead laptop
1.Turn computer off
2. Remove the battery, charger and all accesories connected.
3. Press power button for 1 minute
4. Connect the power adapter only.
5. Turn on the computer.
If not turning on and not even boot to lenovo screen then posible issue with the hardware. call the manufacturer if you are still within warranty they can fix that for free.
Mar 28, 2010 | IBM ThinkPad T30 2366 Notebook
Sometimes my computer restarts suddenly.
this problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Nov 29, 2008 | Intel D101GGC Motherboard
My Asus mobo P5ld2 cant turn on
Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
Apr 12, 2008 | ASUS P5LD2-VM Motherboard
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Suddenly quit and won't start.
Could be a processor failure, but try changing the cmos battery first on the mobo and locate 'JBAT1' terminal on mobo and put jumper across pins 2-3 then back to pins 1-2 and try starting up again.
Jan 09, 2007 | EliteGroup P4VMM2 Motherboard
Biostar TForce4 SLI Motherboard Logo
151 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
