Question about Maxtor Hard Drive
Maxtor 160GB Hi, seems like the DC pins of the of the HDD is shorted, PC doesn't start, tried the HDD in another PC and that PC also did'nt start, where can one obtain a spare PCB for such a drive
  • Stonecamp Jan 15, 2008
    I did some fault finding on logic card of the Maxtor drive 160Gb diamond line, it has a Transky diode, on its 12v dc supply i/p, which is used for overshoot protection, the part number of this device (bux c430, made by ST electronics), is however not found any ware, and seems it is a component made especially for maxtor. I contacted ST electronics, and they did'nt even had this device on their data base, the equivalent for this device is however the SMA12A, or SMBJ12A, which solved the problem.
    Regards,
    stonecamp
  • 2,427 Answers
Sorry to tell you this,, but the only way you are going to get that, is to get an old harddrive and scrap it,,, Or you will have to buy a new harddrive , since indivuidal parts are not sold seperately... BTW IF YOU ARE PLANNING TO ATTEMPT TO REPAIR IT ENSURE YOU ARE USING A CLEAN ROOM ""CLEAN""
Posted on Jan 11, 2008
Installed new WD HDD (160Gb) into Toshiba Satellite A10-S167. Entered BIOS edit, but can't get laptop to recognize the new HDD (which replaced a smaller, failed HDD)
Shouldn't have any problems on the A10 series working with a 160GB drive, so long as it's an ATA/IDE type with a 44-pin connector. If it's not recognizing the drive, could it be that the pins were not precisely lined-up with the IDE connector? I'd remove the drive, make sure the pins are still all straight, reinsert it into the HDD compartment and see if it makes a difference.
Aug 31, 2011 | Toshiba Satellite A10-S167 Notebook
Which are the slave pins on Maxtor diamondMax Plus 9 160GB ATA/133 HDD harddrive???????????
Look for a grid of gold-coloured pins between the power-connector and the data-connector.
Look CLOSELY at the engraving on the top of the disk-drive, near those pins,
looking for 'MA(ster)' or 'SL(ave)' or 'C(able)S(elect)'.
Or, especially for MAXTOR drives, read the text printed on the label on the top of the disk,
for the "pairs" of pins that need to be set.
Nov 08, 2010 | Maxtor Hard Drive
How do i reformat (NTFS) my maxtor Basics 160gb external drive to get it back to 160 - it only shows 149gb
it is usual, that you wont be able to access entire 160gb...certain amount of disk space will be reserved in the HDD for boot sector...
Sep 29, 2010 | Maxtor BASICS Personal Storage 3200...
My 160GB archos 504 hdd was badly fragmented. I tried to use my pc to sort the problem but the archos seemed to disconnect from the pc about 16% through the defragmentation, next I tried using the archos...
if you can use 10gb of your hardisk its means its not totally broken... first make sure theres no partition of your hdd... because hdd can split into 2 or 3 or more...example the first partition is 10 gb and the second partition is 50 gb and the ramaining partition is 100gb... try to format your hdd in... first click start right click my computer choose the manage and computer management will apear then click the disk management and it will show if your HDD is have partinion that no have drive letter just right click it and you can rename it or delete... or you can reformat it...
Feb 28, 2010 | Archos 504 500870 Digital Media Player
Install driver of maxtor 160gb onetouch 4 mini
Hmmm What software do you need?
You should not need software to run the HDD. Just plug it in.
You can get the One Touch software from Seagate (who no own Maxtor) See
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot4-downloads&vgnextoid=0ed72c9e46914110VgnVCM100000f5ee0a0aRCRD
HTH
Dec 08, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
I need to know the power rating for a Maxtor 160GB external Hard Drive for use with a Yamaha PSRs-900 keyboard. Yamaha requires the rating to be not greater than 500-600mA
The Maxtor STM901601EHD301-RK is part of the Maxtor Basics Portable family.
It uses a 2.5 inch Internal harddrive inside. (2 and a half inches across the Width. Same size used for a laptop. Desktop's use 3.5)
It connects with a USB Style A male plug, via the USB cable.
It's has a 160GB storage capacity, has an 8MB Buffer, (Cache), and an External Data Transfer Rate of 60 MegaBytes per Second.
Other than that, I find no more information from Seagate, (Seagate bought out Maxtor, and has the data base for Maxtor products)
http://hddlist.com/maxtor/all/maxtor_basics_portable
What I do know in reference to your question.
I know that the USB 2.0 technology uses 5 Volts DC. The Positive pin on the USB plug will support up to 5 Volts.
http://en.wikipedia.org/wiki/File:USB.svg
[Viewing a USB-A style plug, view it with the white plastic spacer at the bottom. Open part at top. The Positive pin is all the way to the right. The Negative pin all the way to the left. The Data + pin is on the left next to the Negative pin. The Data - pin is on the right, next to the Positive pin]
The Maximum current draw is 500 mA for a USB 2.0 port.
[ Current is rated in Amperes, or Amp's. You are looking at Millionths of an Amp.
Milliamp, or abbreviated as mA]
This would lead me to believe that the Maxtor Basics Portable external harddrives will not use more than 500 Milliamp's.
However I do not feel comfortable, telling you that it is okay to use your Maxtor STM901601EHD301-RK, on your Yamaha PSR2-900 keyboard. Would hate to be mistaken, and have you burn out the finals of your keyboard.
I do feel comfortable with the following suggestion.
What about transferring as much data as you can from the Maxtor Basics Portable, to a USB thumb drive? They have large thumb drives now, and hold a lot of data.
Most programs will fit on a large USB thumb drive.
Or am I missing the point somewhere?
Oct 20, 2009 | Seagate Maxtor OneTouch 4 Mini 120GB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
MAXTOR 160GB HDD PN:9NX2A4-500 WILL NOT WORK ON MY PS3
the ps3 does not support many external hard drives.
But they do accept USB Flash drives/thumb drives.
Aug 07, 2008 | Computers & Internet
Maxtor Hard Drive Logo
88 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
