Question about NetGear WGPS606 (WGPS606NAR) Print Server
Netgear Wireless Print Server WGPS606 won't install correctly
I have a Windows XP desktop and Windows Vista laptop that we want to print to a Canon MultiPass 730 printer/scanner/fax with a WGPS606. Can't even get through the install...we've spent days (literally) with insufficient instructions from the manuf., and little web site reference on how to accomplish this.
  • 3 more comments
  • Anonymous Feb 17, 2008
    During the install, I get a meaasge indicating the computer and the server are't cpmmunicating and it suggests turning the router/server/computer on and then back on (which I've tried) and also that the codes between the router and srever may not be the same. I don't know how to determine this part.
  • Anonymous Mar 04, 2008
    Installed printer set up cannot get the pc to see server.tried everything.Changed IPaddresses confirmed with NETGEAR what IP to use with my NETGEAR router. Nothing
  • Munawar Khan Mar 10, 2008
    My print server is not recognized by the setup soft ware. It is connected to the computer by ethernet cable. It says," Installation assistant can not detect your print server."
    Please help
    makhan380@hotmail.com
  • Anonymous Apr 21, 2008
    Have tried many times to install prints erver and cannot get printer to work thrugh WGPS606
  • networkmagic May 11, 2010
    As with most network problems, the solution usually starts with more questions than answers....how are you trying to set up the print server...are you using the Netgear "Smart Wizard" software? If so, are you running it on the XP or Vista machine? Is the XP desktop connected directly to the print server with a network cable? Is there a working Internet connection in this scenario?
    Here's my (uninformed) summary of recommended steps:
    1. -Make sure Windows XP has been updated to Service Pack 2 level.
    2. -Follow the instructions and run the "Smart Wizard" software on the XP PC to set up the print server. If this step fails there is a deeper problem that needs to be corrected. Don't try using the Vista PC until everything works with the XP PC.
    3. -Once the XP PC and printer are working, refer to the Netgear web page (link below) and procede with setting up the Vista PC to print.
    http://www.netgear.com/vista
I finally got my WGPS606 installed - unfortunately, it's just on one computer so far, but that computer is on the network and is not wired. Here are a few tips:
1. hold the reset button (little pinhole) until you see some action going on with the lights (I forget exactly what happened, but after a while there was a change) - this served to "reset" my WGPS606's IP Address, which I had changed during setup.
2. connect your computer to the server with an ethernet cable and type in http://192.168.0.102 (the default IP Address of the server)
3. login with the default username and password:
username: admin
password: password
4. once logged in, you will see all of the WGPS606's information. At that point, you should be able to change the IP Address of the server to what you want it to be, but I think you can proceed to run the setup on the installation CD (or the installation program from the WGPS606's Netgear website) and it should be recognized on the wireless network.
In my case, I want to mention that when the initial setup failed for me, I used the MAC address on the back of the server. After steps 1-4, my server was finally on the wireless network by the installation program, however, the MAC address was 1 digit off from what was on the server. The MAC address on the back of the server was the PHYSICAL MAC address, whereas the WIRELESS MAC address was one digit higher (last set of numbers. For instance, on the back of the server, the MAC address ended in ":01" and I found out that this was the physical MAC address. The wireless MAC address was exactly the same, except the last 2 digits were ":02."
Another thing to note was that after the server was recognized, it told me to reserve a specific IP Address other than what I had previously set - I didn't realize that it chose it for you. Anyway, just keep that in mind. After this, everything worked like a charm - well, I have yet to set up the other computers to connect to the server, but at least I have one!
Hope this helps!
Posted on Nov 21, 2008
  • flexgrey Nov 21, 2008
    One more thing: once I got the WGPS606 connected to my network, it did NOT appear as an attached device, so the only way you can tell if it is connected is by logging into the server. And since the IP Address got changed by the end of the setup, you have to enter in the NEW IP Address into any browser and log in as described above. Once logged in, you can also change the username and password.
My laptop computer with Windows Vista OS could find the printer server but I still could no print although I had disabled window's firewall. Later, I found there was a personal firewall setup from the anti-virus software. After uninstalled the personal firewall, I could print through the WGPS606 printer server without any problem.
Posted on May 24, 2009
I had to turn windows firewall off during installation in order for the set up software to find the print server.
Posted on Aug 14, 2008
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Cannot install netgear wgps 606 wireless print server on vista laptop. I have 2 other laptops with windows xp and have no problems setting up the print server. I get message that the subnet address needs...
Here's the toll free number for
  • Netgear Tech Support 1800-211-2069
  • Netgear Tech Support 1-888-638-4327
  • Make sure that you are able to go online when the modem is directly connected to the computer.
    Contact the above numbers for a first call resolution.
    Good luck.
    regards.
    Apr 08, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
    Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
    Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
    Regards gaz
    Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
    WGPS606 does not like printers
    Hi, visit the link below to check the compatibility list of this print server. If your printer is not listed then it means that it has not been tested with this print server and there is equal chances for its nonfunctioning with the print server.
    for further support with any netgear product visit my.netgear.com
    Do rate it, if it helps.
    Regards
    Anand
    Aug 02, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
    My wGPS606 wont print on my Windows Vista laptop!
    I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
    I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
    BUT!! (with thanks to another another forum):
    I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
    Under the 'Ports' tab I deselected 'Enable bidirectional support'.
    Problem solved.
    Hope this helps.
    let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
    The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
    Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
    May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
    My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
    there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
    Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
    Connecting the WGPS606 to Dell AIO 962
    Try installing a lower end printer to the same port. For example HP LaserJet 3.
    Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
    Installation assistant cannot detect print server
    Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
    Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
    Problem printing to wireless print server
    I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
    Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
    Open Questions:
    NetGear WGPS606 (WGPS606NAR) Print Server Logo
    5,601 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
