Question about Toshiba Satellite A135-S4527 Notebook
I need to no how to go on my computer as a amenastrater
    Problem Solver:
  • 18 Answers
First, you need an account that's an administrator. Typically, the administrator account that is built into the operating system is disabled by default and can be enabled in the Local Security Settings in the Control Panel. Without an administrator account, you won't be able to make the adequate changes.
Posted on Nov 19, 2009
I try to run a game but it seems he needs hardware acceleration graphics. i want to know if there is a program i can install to make the game work or my computer needs a sort of component.
Hardware acceleration is computed via a graphics card, a physical piece of equipment. A program would be Software acceleration and this is not needed to run the game.
Yes you are quite correct your computer does need a component, it is called a graphics card. There are many graphics cards available, some more powerful than others. Contact a computer store, look around and talk to them about upgrading your computer with a suitable graphics card.
They may need to see your computer to know what slot type of graphics card your computer accepts.
Take care and happy gaming!
damnor01
Sep 11, 2011 | Acer (9005210464), (64 MB) Graphic Card
Tip
Computer Repair Services
Computer repair includes software and hardware repair. Hardware repair is needed when any part of the computer is not functioning as expected. Software repair is required when any software program is not executing properly.
Need of computer repair
Computer repair is needed for making your computer function properly. Your computer will function properly if all its parts are working properly. Some of the issues for which you require computer repair are as follows:
• Computer automatically shuts down
• Computer takes much time in launching applications
• Computer system crashes or locks up
• Blue screen error
• Computer makes beeping sound when switched on
The reason for most of the computer issues is the lack of maintenance. For maintaining your computer and optimizing its performance, you have to update software regularly, clean registry, empty cache files and many others.
In case, you have the knowledge about how to repair your computer, you can perform it yourself. But if you do not have any knowledge in this field, then you can contact a computer support technician.
Computer repair technician is a person who will repair your computer either through online or on-site. Online computer repair is preferred in case your computer needs software repair. If you want to go for online computer repair, all you need to have is an Internet connection. Online computer repair saves your from the pain of taking your computer to some technical services center or inviting some technician at your own residence.
These days most of the companies offering online computer repair adopt the method of remote desktop connection. Technician will access your computer with the use of software made for remote desktop connection. But you have to give him permission for doing so. After getting permission, he will diagnose your problem and after that resolve it. Technician will install, reinstall or uninstall any software, or modify some of the settings for resolving issues.
In case of hardware repair, you have to call a technician in your premises. Technician will diagnose all of your peripheral devices, in case of any faulty one, he will replace that one. He will also update drivers of peripheral devices.
So, it can be said that computer repair is required when your computer is not functioning as expected.
on Feb 04, 2010 | Computers & Internet
I have a 8 port ethernet switch DES-1108 how do i connect it to a DSL cable modem and the 3 computers i have . do i need to use the router still. or what
If the computers only need to communicate with each other then you do not need a router.
Each of the computers must have the same Network name (workgroup) and have the same IP address range. If you have a fixed IP address on each of the computers the IP address range should be the same - for example 192.168.3.xxx (xxx being a number unique to each of the computers, BUT the first 3 group of numbers (IP address range) MUST be the same on all the computers.
If the computers need Internet access then a router is required and if there is insufficient LAN ports on the router then you need to add a network hub connect the router to tht hub and connect the computers to this hub. You would need to configure the computers to obtail an IP address automatically, the router will issue IP address to the computers automatically.
I would not recommend using the Ethernet switch with the router as it would require a more complex configuration.
May 13, 2011 | D-Link DES-1108 8-Port Ethernet Switch...
My computer is very slow connecting to the internet and then very often locks up
This may caused by a malicious software such as viruses or worms that may have been downloaded on your computer online.
You need to run a scan on your computer to check. You can actually use Malwarebytes or Super-Antispyware if you do not have any Anti-Virus software that you can use.
Also, you need to optimize, or clean your computer against clutters, temporary internet files or temporary files that are stored in your computer. You can run CCleaner to delete the temporary files on your computer.
Also uninstall programs that you no longer need to free up memory resource/use on your computer.
If all else fails, you might want to check if your computer needs to upgrade the RAM to make your computer run faster.
Apr 06, 2011 | Dell Computers & Internet
Need to connect modem to two computers so one computer can access work vpn.
Depending on how you set up the first computer, you can have one computer connected by USB and another by ethernet (straight-through cable). If you want both computers connected by ethernet, you need a crossover ethernet cable between the Modem and a router or switch (hub). You will need a straight through ethernet cables from the router to each computer.
Then set up each computer as appropriate for the type of connection (including installing drivers for the USB as needed). For more details see: http://broadband.motorola.com/consumers/products/SB4220/downloads/SB4220_userguide.pdf .
I hope this helps.
Nov 06, 2010 | Arris SURFboard SB4220 Modem
Computer won't turn on completely. I can hear it but the screen is black
Try connecting a different monitor to your computer.
If it works, then your monitor needs to be replaced.
If not, then the video-card in your computer needs to be replaced.
Try connecting your monitor to a different computer.
If it still is "black", then your monitor needs to be replaced.
If your monitor works, then the video-card in your computer needs to be replaced.
Sep 28, 2010 | Computers & Internet
I want to singn on as amenastrater can you help me
if it is windows xp you can just type in the username box administrator and your in as administrator. If it is windows vista you would have to go into windows command prompt and enable the hidden administrator account.
Nov 19, 2009 | Toshiba Satellite A135-S4527 Notebook
How should i find my computer access code
need more info bios code,windows code,windows op serial code? please be detailed
Jun 29, 2009 | X2 Systemax NO OS AMD Desktop Computer -...
Help do ineed drivers4 player
You don't need a driver for this MP3 player in order for it to be recognize by your computer, just need to connect it properly to a USB port on your computer and wait for about 30 seconds to a minute for your computer to fully recognize and install the necessary drivers that it needs, if its not recognize by the computer try to connect it on a different USB port on your computer....
Oct 20, 2008 | Electronics - Others
Toshiba Satellite A135-S4527 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
