Question about Panasonic KX-T7731 Corded Phone
I need help programming the phone to pick up CO1
When I pick up the phone to make a call, the line picks up on CO2 and should pick up CO1 instead. How can I fix that?
  • 1 more comment
  • stephanie682 Nov 20, 2009
    There are two lines, CO 2 is a seperate number but currently disconnected so it can be used for the fax.
    CO 1 gives me a dial tone, but I have to push the CO1 button first because the phone automatically goes to CO2 when I pick up the receiver.
  • Carl Navarro
    Carl Navarro May 11, 2010
    Is there something on CO2 and what System is the phone connected to?
  • Oliver May 11, 2010
    Hello, Please find below original manual for this phone. There is whole chapter about how to program the phone.http://service.us.panasonic.com/OPERMANP... Hope it helped.
  • Panasonic Master
  • 2,460 Answers
This is a guess because you still didn't tell me what system you're connected to. On an idle phone, try pressing PROGRAM 131 STORE. In a TA-824, that makes you select line 1. If it's busy, nothing happens.
Carl
Posted on Nov 20, 2009
Testimonial: "That worked!!!! Thank you SO MUCH!"
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
Determining which CO you get when pressing 9
Set outgoing line preference.
Or simply swap the CO1 and CO2 line plugs.
The plug from your service provider that enters in CO1 put it in CO2 port and vice versa.You may need alittle config as well.
Oct 26, 2012 | Panasonic KX-T7730 Corded Phone
I had a KX-T7730, i have 2 line and use to be store as CO1 & CO2.. then other time when i try to store a speed dial.. everything got mix up.. now when i colleague hold a call, i can't pick up the call...
From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
Carl
Apr 18, 2011 | Panasonic KX-T7730 Corded Phone
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
I can't access my co1 outside line on the KT-x7735
It could be a couple of things. First, press PROGRAM and the CO1 button. If it does not say CO-1, then dial 0 1 STORE and it will.
If it does, you probably altered system programming and that line is now restricted from the phone. That requires Installer system access to the programming from the phone connected to the first jack in the cabinet.
Carl
Jul 12, 2010 | Panasonic KX-T7735 Corded Phone
Panasonic kxt7630 button assignment
I've never heard of the ability to reassign an intercom button as it's a fixed feature, but maybe so. Start by assigning the lower left phone button back to CO1 and let's see what happens. WIthout picking up the handset, press PROG the button and dial 0+01 STORE or ENTER.
Pick up the handset and drop it back in the cradle to exit programming.
Did that work? Making button 1 into CO1 will drop the programming from the intercom button and it should default back to intercom.
Carl
Apr 15, 2010 | Panasonic KX-T7630 Corded Phone
I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Apr 22, 2009 | Panasonic KX-T7730 Corded Phone
Programming CO Pick Up Order
It can be done. Need to know the model of the phone system
Jan 21, 2009 | Panasonic KX-T7736 Corded Phone (KXT7736)
INCOMING CALLS
Swap phones with a known working one. If it is really the position, you'll have to read the buttons. Go to a working location and dial PROGRAM 99 press the buttons and write down what they say (ie CO1 CO2 etc).
Then go to the non-working phone, press program 99 and the same buttons. If they don't say anything, then dial 0 01 store
press the next button and dial 0 02 store, etc. Do that on all 6 line buttons.
With luck, the phone will remap to the proper lines.
Carl
Aug 22, 2008 | Panasonic KX-T7433B Corded Phone
Panasonic KX-T7731 Corded Phone Logo
355 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
