Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Motor made a grinding sound and stopped. Took out brushes to check. They aren't badly worn. Motor is cooled now and still won't start.
  • 235 Answers
BGL0514 - Are you sure the grinding sound was coming from the motor, or was it more likely coming from the transmission? It appears that your mixer had a mechanical failure in the transmission box or planetary gear assembly of your mixer - one of the main gears has failed, hence the loss of power to the agitator.
The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Here is a link to an excellent webpage for disassembling/fixing your KA Mixer: http://www.neilcrockett.com/mixer.htm
Finally, with respect to your brushes that you removed, I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor, so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Posted on Nov 20, 2009
Testimonial: "Thanks. Motor came on after 3 hour cool down. Still making the grinding noise. If it goes out again, I'll try the diy option."
    Novelist:
  • 143 Answers
It sounds like you may have an issue with your motor control board. When this is faulty it can cause an irregular motor rpm or no motor what so ever. You can check this by first removing the power and then remove the back access panel. Now you can see the motor control. Visually inspect the board and smell for any burned connections. Part number for the board is W10119326. Hope this helps.
Thanks
Posted on Nov 22, 2009
Kitchenaid connection problem?
The bad sparking can be several different things. The bad sparking at contact points or burned contracts on the switch can be caused by a faulty phase control or wrong wiring. Open the mixer, check wiring, if that is correct remove an replace the phase control board.
If the bad sparking is at the motor brushes this can be caused by worn motor brushes, rough commutator, faulty armature or shorted motor field. First remove the brushes and check that they are not worn to less that 5/16'. Replace with new brushes if excessively worn. If Brushes are fine remove and check armature. you will most likely have to replace the motor/armature assembly.
Thank you,
Colleen
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
I have a 6 qt kitchen aid mixer and the gears look fine all metal, it makes a humming noise but nothing moves. Any suggestions
If you haven't solved this problem yet, I have a couple suggestions.
Take off the motor housing, be VERY careful where the exposed electrical contacts are, then plug it in and turn on the motor with no gears attached. If it spins, cycle through the speeds to make sure they all work, then if they do, revisit your gears. Turn them all by hand and make sure they move easily and smoothly. Make sure the teeth aren't too worn down. I don't know what model you have, but also check anything that holds gears on or in place to make sure they aren't loose or cracked.
If the motor does not spin, look at the brushes (you could start by doing this if you wanted to, since they are far easier to take apart than the motor housing, but my guess is this isn't the problem). If the brushes are worn down to near the spring, buy new ones. If the brushes look fine, then either get real brave and pull open the motor to look for broken or worn out parts, or call an electrical engineer friend, or send it off to kitchenaid or a repair shop.
Oct 30, 2012 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid mixer Model K5SS, Ser #W83808959. The motor stopped running and in checking the brushes, I found they are are both stuck in the brush holders. I suspect this is the reason the motor...
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Jul 30, 2011 | KitchenAid K45SS Classic Stand Mixer
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
Jul 15, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
The motor humms but does not spin on 250 watt mixer. Took out brushes and reinserted and played with speed control. Started spinning but does not sound correct.
When you took out the brushes did you clean the armature? Sounds like you need to remove the brushes and using crocus cloth (available at Lowe's) clean the armature. If the armature is very rough (lots of grooves) you may need to use a file first, but only if you know what you are doing as some damage could occur, and smooth it out without taking it out of round. I would also recommend replacing the springs and brushes. Check www.repairclinic.com for parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 03, 2010 | KitchenAid Food Mixers
Sunbeam mixmasters 2358 stop working suddently
Check the condition of the motor brushes and springs. The springs should have a bright brass look and not be collapsed. The brushes should not be broken or worn less than 1/4 inch long.
Feb 11, 2010 | Food Mixers
Mixer works on high speed but not low. Brushes
Motor brushes are fairly cheap to buy. It sounds like the first place to start: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 11, 2010 | KitchenAid K5SS Heavy Duty Commercial...
My kitchen aid mixer makes a clicking sound when it is on and will not mix properly. It spins, but sounds bad.
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Mar 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
Kitchenaid ultrapower ksm90
Yes, First unplug the unit.On either sides of the mixer there are two black motor brush retainer screws. Carefully remove them paying attention to the motor brush keyed position.You will see that one side is keyed.Check to see if the brush is competely worn down,or possibly cracked ( replace ).Always reinstall brushes the same way they came out.This should solve the problem.
Nov 03, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
249 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
