Question about D-Link DSL-G604T Wireless Router
PS3 Wireless connection
Keep getting error message on connection, any help?
Cheers
Alan
  • Anonymous May 06, 2008
    I'm trying to set up my PS3 to connect with my D-link router.  It keeps timing out when trying to aquire an IP address.... any ideas?
  • Anonymous Jul 04, 2008
    my sons ps3 was fine to start with but since our pc's gone down (being fixed today) he just keeps getting dns error with a long error code ?? what does this mean?? my laptop is working fine, hence this message, with good signal.
Same problem to me.
I can use my laptop in my livingroom with 100% wireless signal but my ps3 gets 60 to 80 tops and doesn`t stay connected for to long.
Posted on Jun 15, 2008
    Problem Solver:
  • 6 Answers
Is your error message relating to security or what exactly? Please try and post the error you are receiving.
Posted on Jan 11, 2008
Can not log onto the PSN. error message 8002AD3D. I have relocated my PS3 to a different state and I'm using a NET40 wireless signal. The strength of the signal is stating 100% in the network settings....
Hi kdfrance
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Try turning off media server on ps3 Go into the PS3?s Settings menu and navigate to Network Settings - Media Server Connection disable it thats my first idea which could be causing the issue..Secondly unplug your modem/router for 15 sec then plug back in...THEN FOLLOW STEPS
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection" or "Wireless Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Hope this info was helpful cheers nikki
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Unable to get wireless access to internet on ps3, keep getting a connection error DNS 80710102 or 800100A, can you advise how to resolve?
Try to disable the security key of your wireless router in the meantime and try to connect your PS3 without the security turned on. If it connects, what you have to do next is to reset or generate a new security key on the wireless router and setup the PS3 - wireless network connections with the new security key.
May 26, 2010 | Sony Playstation 3 (PS3) Console
Keep getting error message 8001050f
tazosc
For right now I have learned that Sony is having a network issue with the PSN.
However if you keep having this error alot then you might be having network problems. Let me know if you are connecting via wireless or wired. Also let me know the make an model of your router.
Issken
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
I keep getting a DNS error when I try to log online
you should verify your internet connection with your provider; DNS error usually happens when connection fails.
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
Internet connection timed out
make sure your wireless router is connected correct
go into windows device manager and see if your device is working right
if not give your computer maker a call
hope that helps
cheers
Jul 19, 2008 | HP Pavilion dv6000z Notebook
Wireless router wont connect
Hey mentalmc,
I had this problem at least once a month. Try these things out.
1. Make sure any WEP codes are entered EXACTLY as it is for your router.
2. Set up your router so only your PC connected to it can change any settings.
3. Turn off your PC while trying to connect via PS3 WiFi. The good ole Win update likes to download without you knowing it sometimes.
4. If all else fails, call Sony cause you may have a bad WiFi antenna or motherboard.
Jun 25, 2008 | Sony Playstation 3 (PS3) Console
80029c41 error code
When do you get it?? If it helps when your trying to connect to the internet i suggest you disconnect the PS3 from the wireless connection and try it again if not get a better and faster and more ranged wireless Connection.
Rate my Solution Please
I tried my best.
Apr 30, 2008 | Sony Playstation 3 (PS3) Console
PS3 wireless connection and configuration problems
I don't know if you've tried Sony's website, but check this link http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html and see if anything there helps. It sounds like the PS3 isn't detecting all your settings automatically.
Nov 25, 2007 | Sony Playstation 3 (PS3) Console
HELP PLEASE
You need to sign up to the ps3 wireless play just like xbox live but without paying. go to the sony website to find all the info.
Sep 13, 2007 | Sony Playstation 3 (PS3) Console
D-Link DSL-G604T Wireless Router Logo
642 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
