Question about Power Acoustik LT-980/2 Car Audio Amplifier
I have a power acoustic gothic series 1600 watt amp, it was playing fine last night and just went off, protect light on. Today i tried it, there is a very small amount of sound thru the speakers but thats all. what could my problem be?
  • 26 Answers
There are really only two possibilities here. If you have the gain turned up too high then your amp will get over worked and will go into protect mode. It is a safety feature. You should never really have the gain at much over 50% up. If you have to consistently run it higher than that you are overworking your amp and it will either shut down to protect itself or you will fry it.
Posted on Nov 19, 2009
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Problem
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
Apr 04, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
284 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
