Question about Linksys WRT120N Router
My router doesn't detect my modem.
My computer is reading the modem and the router individually but the router isn't connecting through.
  • moederre May 11, 2010
    Would need more info on what the error message might read. Perhaps you need to reset the router? Do you know how to logon to your router? You can also do a live chat with a Linksys technician online and they will help you set up your router correctly.
  • 2,260 Answers
That means the router is not communicating with the modem.
If you connect the computer directly to the modem it works. you are online. But if you conenct the router to the modem and the computer to the router it does not work ?
I believe you will need to reconfigure the router .
Reset the router for 30 seconds. Unplug the power to the router . plug it back in. wait for 1 minute.
Not access the router set up and reconfigure the router.
Click Here for more info about rotuer set up.
Posted on Nov 20, 2009
Cannot connect to the internet. Have the wireless USB piece and is set up, but will not surf.
  1. Test your internet connection by directly connecting your modem into your computer.Bypassing the router.If it doesn't connect to internet then your router isn't the culprit.Contact your internet service provider for your area.If it does not connect then follow below step.
  2. Reconnect your router to the computer.Turn on your computer and find program associated with router.Select "options" select security options and select security mode and turn your router off.Attempt an internet connection. If it does not connect to the internet then your router might have broken and tell it to a company. If it does connect then your computer may have experienced a security breech that router does not allow it.
  3. Run a virus scan or malware scan for your computer.
If you have further query then contact me. Thanks for using FixYa.
Sep 04, 2011 | Computers & Internet
D-Link wireless router has been greta, until yesterday- the Roku boxes say my router strength is excellant, but all of a sudden, the box can no loger connect to the Internet even when I select my router-...
The router most likely is not synced properly with the modem. Your computer might still have a strong connection to the router, but isn't getting an IP address. Power everything down, including the modem and restart in this order:
1. Modem - allow a minute for it to run thru its diagnostics 2. Router 3. Computer
Once you've done this, if you're ISP isn't having outages, you should have the internet working again on your computer. If this doesn't work, call your provider.
Jun 19, 2011 | D-Link DIR-615 Wireless Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
How to change 192.168.0.101 to 192.168.1.1? because, 150mbps from router, but actually the speed is 11 mbps, tks
Really depends on what router you have and why you want to do that,
192.168.0.101 sounds like a computer IP,
192.168.1.1 sounds like the router IP.. changing the IP addresses will have no effect on your connection speed.
Also just because the router says it's capabale of 150mb/s doesn't mean your internet connect can support that speed.
Typically with Cable Modems your connection will say it's established a 100mb connection but in reality you're sharing that connection with everyone else on your "node" so you getting 11mbps isn't actually bad for a standard cable internet connection.
Jun 01, 2011 | Computers & Internet
My laptop can detect the router but is not
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Apr 18, 2010 | Encore ENHWI-G2 Router
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Netgear 3G Broadband Router won't connect to the internet
Please note that the USB Modem will not cause issues related to IP address conflict(NAT behing NAT)
You need to mak sure that the USB modem is compatible with this router. As per the compatibility list this modem is comaptible.
http://www.netgear.com/Landing/en-us/3G_uSB_Modems
Please reset the router once and then upgrade the firmware on the router which can be downloaded from thelink below:
http://kb.netgear.com/app/answers/detail/a_id/7210
after upgrading the firmware, configure the router.
Rate it, if it helps.
Jun 26, 2009 | Computers & Internet
I am getting an error reading saying The computer cannot detect my router...
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- are you using a wired or wireless computer in configuring the router?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 19, 2008 | Linksys Wireless-G WRT54GS Router...
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Mar 24, 2008 | NetGear WGR614 Router
Linksys WRT120N Router Logo
385 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
