Connecting pc to tv
Get no signal using 15 pin connection to rgb(pc) on tv
how do i set up pc
thank you
  • 6 more comments
  • D D Roy Apr 15, 2008
    I am trying to connect my desktop PC to the TV monitor but I am not getting any kind of display. Please let me know what I need to do to get this product working with a PC connections. Thanks.
    D D Roy
  • jw45 Aug 18, 2008
    I need to run powerpoint on 34"LG in full screen mode.I have had the show running in "keep to aspect ratio" mode where the powerpoint presentation sits in the middle of the screen with a large black border around it.Now have the message "no signal" floating around the screen no matter what I do!
    Who can help please
  • Anonymous Oct 21, 2008
    WHEN CONNECTING MY PC TO TV I GET THE START UP SCREEN AND THEN THE MESAGE UNSUPPORTED SIGNAL
  • sellenburg Dec 15, 2008
    where can I find the Vista drivers for the Polaroid 2611
  • Anonymous Dec 17, 2008
    what cabl do i need
  • scott77scott Jan 01, 2009
  • Anonymous Mar 11, 2009
    Trying to connect HP dv6448se to Sony 40" Sony Bravia 1080p. Nvidia card recognizes the tv and settings fine.
    From S-Video to RGB (Component 1) TV says "No Signal".
  • Anonymous May 03, 2009
    i have a vizio 38'lcd when i connect the rgb cable to the pc i get picture on my tv but not on my pc
  • 2,427 Answers
What you need to do is right click on your deskdop, and select your videocard settings ,,, for example miune is Nivida Display,,,
any way you have to select your, It should automatically detect the tv you have connected and all you will need to do is set it up... if it doesnt detect the tv, there should be an option to detect it for you mine is in tools...
Sorry i couldnt give you a step[ by step procedure, as it varys for different adapters..
Posted on Jan 11, 2008
Posted on Mar 25, 2008
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
Trying to connect my laptop to my lcd hdtv.
change it to VGA and put the audio in the mic jack on the laptop and in the audio in jack on the tv.
Jun 17, 2009 | Konka DLC-3211UT 32 in. LCD Television
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Connecting pc to tv
You need to toggle to the external display by holding the Fn key + F7 or F8. Look at your keyboard and you'll see little TV screen icons. You can also go to start/control panel/display settings or right click on your desktop and access the display properties.
There is usually two tabs with two displays and the active current display in from. Click the other and adjust the resolution and type using the drop down menus.
You might need to consult your TV manual as well to make sure your in the right input mode.
CR
Aug 04, 2008 | Computers & Internet
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
Televison & Video Logo
3,484 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
