Question about Amana Refrigerators
My freezer is beeping. - Amana Refrigerators
    President:
  • 2,702 Answers
This beeping could be the high tem warning beeper,,,check the tem of the freezer if its not -18 or so turn up the thermostst to get it colder, if it still wont stop beeping the thermostat is fualty
Posted on Nov 19, 2009
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
Freezer beeps constantly turned up the temp to the highest still beeping and not freezing its best.
its frozen up or low on gas....the defrost timer has failed or the defrost element has packed it in.the beeping is warning you of a temp failure.
Jul 15, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Frigidaire FRF170FF Freezer beeping
This is probably the defrost cycle. The beeps are the high temp alarm. It is probably overly sensitive.
Jul 04, 2008 | Freezers
Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
Jun 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Beeping freezer??
Also check that there is plenty of room around the air vent to stop the freezer overheating.
Thanks J
Feb 08, 2008 | Beverage-Air Freezer K Series Reach in...
Freezer beeps all time
check the door for tight closure check switch door if working properly (light closes when pushed) windman
Jan 29, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
612 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
