Question about Refrigerators
I have a magic chef ctb2124arb refrigerator and periodically we have water running down the inside. I checked the drain hose in the back of the unit and it is clear. thanks.
    President:
  • 2,702 Answers
Check that the door is closing up tight, if its even just a little bit open it sucks in hot warm air and when this cools it has a lot of water in it, this is were the water is coming from, also if the door is open a lot of times a day that will cause it too, some people leave there fridge door open every time they get things out of there fridge and dont close it untill they put the stuff back in? and all the cold air has fallen out the bottom by then,,so the poor fridge is working its head off and getting no were fast,
Posted on Nov 19, 2009
Where can I find out where the drain hose is located on my Magic Chef refrigerator?
It should be under the fridge. If you remove the lower acess panel on the back you should see a little tray wich is your drain pan. Mike
Mar 19, 2013 | Magic Chef Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water pooling under the vegetable bins on the refrigerator floor enough to fill up the cavity and leak out the door onto the kitchen floor. It is Magic Chef CTB1925DR. We have to constantly pull the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | Magic Chef CTB1821AR Top Freezer...
I have a magic chef refrigerator model ctb1923aba and it leaks water down the back wall and out the front below the crisper bins. I am pretty sure it is a partially blocked drain tube. I am having trouble...
Leo Ponder
imufo2
Aug 17, 2011 | Magic Chef Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Leaking
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 25, 2010 | Magic Chef CTF2126AR Top Freezer...
We have a Magic Chef CTB177GR refrigerator (no ice maker hooked up) that leaks...from where I don't know. I took off the lower back cover, it is dusty but no water present there. I pulled out the crispers...
Good day.
Water can only come from one place, where the frost is melted off the coil in the freezer during it's normal defrost cycles that occur daily.
Two styles. One style allows this condensed water to run down the back wall of the inside of the refrigerator, under the crispers and thru a hole in the bottom of the cabinet into a drain pan positioned
under the hole.
Possible missing pan, not positioned properly, or crack in the drain pan itself.
The other style drains the water to a hose mounted on the back of the machine, down and then into the pan.
Possible hose blocked, not connected properly, or the other items as described in first style.
It's a look-see type of repair.
Nov 17, 2009 | Magic Chef CTB1722 Top Freezer...
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
