Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Does not spin. All the lights are working but does not spin to wash the clothes.
    Problem Solver:
My washer stopped spinning (washing) . I took off the back panel and the long ribbed belt was hanging down, not on the big wheel looking thing. I had read that one common problem was debris in the hose which leads into the pump. So I took off the lower front panel and removed the clamps and sure enough there was a little debris cup that had 75 cents worth of change and other things.
I had noticed that the past 4 or 5 months that the clothes were pretty wet after the wash cycle. I don't know what happened first, but I think the full debris cup was keeping the water from draining out correctly and the belt was stressed because of the weight of the wet clothing. I tried putting the belt back on but it seems to be too worn to stay on correctly. I ordered a new one and hope that those two things will take care of the problem.
Posted on Apr 03, 2010
    Guru:
  • 1,738 Answers
Motor is your problem.
Posted on Nov 19, 2009
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
170 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
