Question about GE Kitchen Ranges
Locked flashes on the ge electric range, cannot use the oven
  • 6,784 Answers
HI. This is a child lock feature that can be released by holding the 0 and 9 pad, simultaneously, on the touch panel for 10 secs, or until the word "LOC", disappears. You must hold both pad buttons down together.
This will release the LOC
NOTE_ If this doesn't release the lock, this will indicate that the main control board is experiencing difficulties.
Posted on Nov 20, 2009
5 Suggested Answers
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Posted on Mar 04, 2009
SOURCE: GE XL44 pilot
I dont know if you recieved an answer yet but this is a fairly easy fix. Open your oven door and remove your bottom oven plate. You now should see the burner element running down the middle. at the rear of the burner element is the ignite r (small porcelin bugger with two wires) remove this and replace with a new one GE #WB2X9154 available from the repairclinc.com website for 69.80 plus shipping. i just ordered (2) they seam to go out like clockwork every 2-3 years. To be safe unplug your ovens 110 volt cord first.
Good Luck
Jim
Posted on Sep 22, 2009
Www.ge.net How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
Jun 25, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
Clock and oven do not work right - lights flashing
The problem could be with the switch that is contrlled by the door lock handle. I disconected the power, raised the burner platform and removed the pannel just over the lock handle. With a hard toothbrush gently clean the contact of the switch.
Good luck
PS
It worked on mine.
Oct 08, 2008 | GE JBP71 Electric Kitchen Range
Oven cleaning
There is a lever just under the cook top and above the oven door with a black handle. You need to move the lever all the way to the right. This locks/seals the door and closes the oven vent so your kitchen doesn't get smokey! Once you do this the oven clean light will stop flashing and the oven will heat up.
Mar 28, 2008 | GE Spectra JBP84SHSS Electric Kitchen...
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
