Question about Maytag Microwave Ovens
I have a over the range microwave oven. Maytag model mmv1153bab. the keypad clock will intermittently lose the time and have to be reset. In using the 30 sec keypad, the unit will fire up for approx 5 seconds and shut down. it doent do it all the time but when the units does work for the full 30 seconds, the display screen will flash some of the keypads other functions. I thought the shutting down problem might be with the doors switch, but in pressing in on the closed door it still will occasionally shut down.
  • konehead34 Nov 19, 2009
    I also tried the hard reset by leaving it unplugged for about an hour. I'm still seeing the flash of functions just before it shuts down, so this makes sense. so how do I remove the panel?
    It makes sense. I tried the hard reset by leaving it unplugged for an hour, but I can still the other functions flash on the display just prior to it shutting down.
    Top Expert:
  • Maytag Master
  • 76,846 Answers
U are going to have to replace the touch pad control panel for this oven, the circuit board is part of the control panel assmebly. the part number is
Part Number: AP4236472 Price $126.41
here is a link to the parts supplier i used as a reference and the page the number came from, it is item #3 in the list
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177372&diagram_id=1321035#d1321035
Posted on Nov 19, 2009
  • yadayada
    yadayada Nov 19, 2009
    before you buy this part consider the age of the oven, is it worth the cost to repair? If it is more than 5 years old i would really consider a new Microwave, they are very cheap these days, the exception is the built in ones
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Nov 02, 2014 | GE SpaceMaker Microwave Ovens
My maytag over the range microwave will only work in seconds and doesnt heat probably because its timing in seconds
Hi, Keypad is going bad, but there may be other problems also...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 18, 2010 | Maytag Appliances Over-the-Range Microwave...
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Getting error code F-3, microwave beeps with this code, entering Clock, then the time clears the code, then can use microwave, but after sitting code comes back on. Have tried unplugging oven for several...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad. It can be intermittent.
On some models, the keypad can be replaced as a separate part.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
But on some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a maytag microwave model # mmv1153aaw..the light and/or air vent turn on all by themselves..I hear a beep, go into the kitchen and the vent is running or the light is on. Is this a fire hazard??...
I have a MMV1153BAB. My service tech mentioned that if use of the surface units overheat the microwave, the microwave fan will come on automatically.
Nov 11, 2009 | Maytag MMV1153A Microwave Oven
Maytag microwave just died.
Take it back to the store and make them do something about them. If they dont then file a complaint with the BBB no reason for you to have to deal with this when it is there problem. It sounds like there is a venting issue and more going on
May 19, 2009 | Maytag Appliances Over-the-Range Microwave...
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
Broken microwave
Then please let us know if the hard reset does not fix it.
(It may need work on the controller or keypad)
Sep 16, 2008 | Maytag MMV5000 Microwave Oven
Maytag,model mmv1153bab,serial #10001847ja,output 1000w
If you still have trouble, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Aug 10, 2008 | Maytag MMV1153A Microwave Oven
MMV5000BAW maytag over-the-range microwave
Found this in the GE section instead of Maytag, but we're happy to answer it anyway.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doen't fix it.
If not, you may have a shorted keypad or bad control panel, either of which we can repair economically.
Please write back with more details if you need further help.
Nov 25, 2007 | GE JVM1870 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
