Question about Whirlpool Washing Machines
Clean water coming from the bottom when it starts
I have a top loader compact and there is clear water coming from the bottom when it starts
    Guru:
  • 1,738 Answers
Serveral things, it can be a hole in the tub, transmissition, to drain hole
Posted on Nov 19, 2009
What lime scale / detergent remover can be used for regular cleaning of my front loader.
Front-loading washing machines are energy efficient and use less detergent than top-loaders, but they sometimes have a tendency to harbor mold and unpleasant smells. By giving your washing machine a quick clean once a month, you'll keep your front-loader fresh, which means cleaner clothes, too. This eco-friendly method doesn't use bleach, costs only pennies to make, and comes together with ingredients you already have on hand.
What You'll Need:
  • 2 cups vinegar
  • 1/4 cup baking soda
  • 1/4 cup water
  • Scrub sponge
Directions:
  1. Start by mixing together the baking soda and water in a small bowl. This is going to be the "detergent" for cleaning the washing machine. Pour the vinegar into a measuring cup and head over to your washing machine.
  2. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. Set your washer to normal load at the hottest water setting. Close the door and start the machine, letting it do all the hard work for you. The baking soda and vinegar naturally break up mineral deposits and any mold growth while cleaning and refreshing your washing machine.
  3. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue. Wipe clean with fresh water.
  4. Your washing machine is sparkling clean and ready to do a load of laundry! Give your front-loader a cleaning once a month to keep your clothes smelling fresh and your machine working in tip-top condition.
Mar 20, 2015 | Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
The service light remains on and the washing will not start.
Hi, make sure there's water in tap that feed machine, if there's, lock off you water, remove hose where it's connected to machine. valve on machine where you remove hoses from, check inside you will see strainer, clean any debris that's there, could be blockage of water entering machine, washer will start only when there's water in it. if it were clog up and you clean it, then connect hoses back to machine, and try it. if that didn't work, then you will need to check, water solenoid valve, that's the same valve, your two water hoses connected to, sometimes they burnt out, especially when there's low water pressure in tap, you didn't say what type of washer you got, top loader or front loader, if you got a top loader, fill it manually(bucket) and it will start, if water solenoid valve burnt out, if you got a front loader, you won't be able to fill it manually, if these tips didn't work, you will have to call mechanic, to make other checks. good luck
Aug 07, 2009 | Washing Machines
Kenmore 3.5 frnt loader always has inches of H20 in rubber gasket
does your model start with 417? if so then there is a new door gasket that will help with water left in the boot.
if you have 110, then there is no new gasket/ boot...
you need to clean the drain pump sump screen.
either unit will have a clean out screen that is a removable cover on the front of the pump and it allows you to unscrew the sump filter and clean it out.
Feb 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Oct 06, 2007 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
