Question about Zyxel Prestige 334W Wireless Router (WYP334WZYXEL)
Windows 7 will not connect to internet wirelessly using netgeat pos.
  • 4 Answers
Try upgrading your lan drivers. That's works for me!
Posted on Feb 05, 2010
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Windows 7 Wireless connection problem
Disable IPv6 from your Laptop & then check ur Wireless Connection...
Also let me know the status...
Nov 12, 2009 | Microsoft Windows Vista Home Premium with...
Problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Why does my WGT624 keep loosing connection. I would be on the Internet and for some reason, I would loose connection to the Internet. I have a Dell Inspiron...1521 computer.
In my case too this happened initially with my lenovo y410 laptop with netgeat router. In laptops if th ewireless network is set with "public" profile then the connection is sometimes dropped by the driver. If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then you can change the wireless settings of your laptop to be in "private" network, which will solve your problem.
Oct 31, 2009 | NetGear WGT624 Wireless Router
My computer wont read my wireless adapter
Enabling Wireless Zero Configuration Utility
Step 1
1. Click "Start" > All Programs > Start up> Right click Netgear utility> click delete...then reboot pc
2. Go to Control Panel
3. Switch Control Panel to classic view ( if it's in category view)
4. Click Network connections
5. Right click Wireless network connection
6. Choose Properties
7. Click Wireless network Tab
8. Tick Use windows to configure wireless network
9. go to Profiles and delete previous connection or SSID
10. Click Apply then Ok
Step 2
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Nov 29, 2008 | NetGear WPN111 RangeMax Wireless USB 2.0...
Setting up Netgeat router.
lawrence15,
i might have picked a factory defect one router..coz a router dont need any setup when u use it..let the store where u bought that replece it..
Mar 02, 2008 | NetGear WGT624 Wireless Router
How many computers can work off of Netgear. My parents are here and are working off of netgeat so when I get on my other computer or my laptop nothing of mine works. Why?
I assume your router has wireless enabled .You need to set DHCP on your router and adjust any firewall setting you might have.Also enabled Network address translation to allow multiple routers to connect to the internet.In this case the number of PC that you can connect is way above home office requirement.
If your router doesn't have wireless capability,you connectivity will be limited to physical connection.In which case you need to set above and have multiple pysical connection.
Hope this helps
Feb 03, 2008 | NetGear WGR614 Wireless Router
Open Questions:
Computers & Internet Logo
146 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
