Question about Kodak ESP 5 Printer
The printer says "paper Jam" but no paper is in it. When ever i click "ok" it makes a loud noise and says "please wait" but it doesnt do anything. What do i do?
  • 262 Answers
Dont worry about that. Try to visit this website this website it will help you to solve that paper Jam kodak.com/go/stepbystep
Posted on Nov 20, 2009
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
My Dell 2135cn printer all the sudden started making crazy loud grinding noises. Then I got a paper jam. I fixed the paper jam and tried to print again, but got the loud grinding noises and paper jam...
Refer to the service manual in disassembling the device.. Clean it thoroughly then try it again.. If, you have no experience in doing so, hire a qualified tech to do so.
Jun 17, 2011 | Dell 2135cn All-In-One Laser Printer
My MP830 will not print. It shows error code 5C10 and makes a loud, quick repeating clanking noise. Any suggestions?
When the printer is not functioning properly it may need to be reset. Make sure that this code is not being generated from a paper jam. Consult your manual for all the ways to check for paper jammed in the printer. (You may not be able to see the paper jam).
Then try a reset as follows:
1) On the printer panel, press and hold the <On/Off> button for one second (the display will go blank). If it does not, unplug the power cord.
2) Wait approx. ten seconds. If unplugged, plug it back in. Otherwise, press the <On/Off> button again.
3) Wait for the machine to cycle through its startup routine before trying a print job.
Dec 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Weird noise from printer carriage
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper. If nothing is found, then likely a hardware error exists.
hope this helps!
Aug 31, 2009 | HP Photosmart 3180 All-In-One Printer
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP Photosmart C5280 Printer
Paper Jam
My printer have an option to clean printer head.. If you too have the option please try it and see..
Sep 07, 2008 | HP Photosmart C4180 All-In-One InkJet...
Paper feed
Hi there.
First of all pull out the paper jam cover - is behind the printer with a clock-like handle. Pull it out and check for any paper or other objects. If U dont see anything try to manualy rotate the black rubber rollers and check for that noise. Locate it and try to describe what you see.
Jun 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
Kodak ESP 5 Printer Logo
444 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
