Question about Jabra BT2050 Bluetooth Headset
No matter how long i hold the power button, the light on my jabra bt2050 will not go solid. It simply flashes slowly 3 times indicating that there is no connection to my phone (it's an enV2 from verizon).
  • 4 Answers
Hold center( round button) for 10 seconds, the light will stay on constant and be in pairing mode.
Posted on Dec 08, 2009
I need passkey for jabra for playstation3
Posted on Jul 27, 2010
How do you put this particular device into pairing mode?
With most jabras you hold down the main button until the light stays solid blue.
Feb 22, 2010 | Jabra BT2050 Bluetooth Headset
I bought a jabra bt 2050...i cant get the led light to stay on..it only wants to flash...and it wont pair with my blackberry storm
Try to press and hold the center on/off button for 10 seconds, this will put the Jabra BT2050 into paring mode.
Assumptions made:
1) The BlackBerry is Bluetooth enabled.
2) The Jabra BT2050 is fully charged.
Hope this help.
Joseph
Jan 05, 2010 | Jabra BT2050 Bluetooth Headset
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Jabra BT2050 Bluetooth Headset not found on cell phone? I turned on the headset, and when i search for it, the headset doesn't show up. My phone just says "no new devices", and its not a known device
Try pairing it again. Make sure Bluetooth is enabled on phone, turn the BT2050 on by pressing and holding the side power button. Then, press and hold the center (round) button for at least 10 seconds (light will stay solid and it is now on pairing mode). Follow instructions on your phone. Hope this helps.
Jabra BT2050 blinks three times; doesnot pair up
Hold round center button for 10 seconds, light will stay on and be in pairing mode.
Nov 20, 2009 | Jabra BT2050 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Problem pairing my Jabra vbt 2050 with my blackberry storm
Hold the volume up (+) button down along with the call button for 5-10 seconds (until the led lis solid). Then, while the led is lit up, initiate the pairing on your phone. It should pair this time. It worked for my phone, which was having the same problem you described.
Mar 04, 2009 | Jabra Bluetooth Headset with Adjustable...
Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Feb 03, 2008 | Jabra BT125 Headset
Won't go into pairing mode no matter how long I hold the answer/end button. Yes, I start with the device powered down, hold the a/e button, blue light flashes every few seconds but never goes solid. Any...
You need to turn it on so you get the intermittent flashing blue light then hold down the + button and answer button at the same time until you get a solid blue light. Then get your device to search for the headset etc......
Nov 27, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2050 Bluetooth Headset  Logo
924 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
