Question about Kenmore Washing Machines
LOC Error Code on Kenmore Washer model 417.44082400
  • 6,784 Answers
Hi.The control is in a "LOCK" feature. Press and hold the Options and Select at the same time until the "LOC" led goes off to take the control out of "LOCK" or to put it into a control "LOCK".
NOTE_ If this standard procedure doesn't release the lock, this will indicate that the main control module is damaged.
Posted on Nov 19, 2009
SOURCE: error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Posted on Nov 24, 2007
blueextc3221
  • 15935 Answers
SOURCE: we are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Posted on Jul 27, 2009
  • 96 Answers
SOURCE: Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Posted on Feb 17, 2008
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
pastorey
  • 47 Answers
SOURCE: washer will not start error code says "LOC"
hold the option and select buttons at the same time for several seconds and it will "unlock" the control panel hold it for a very long time keep them pressed as you turn the dial
Posted on Dec 09, 2010
Flashes LOC and won't start
The solution to the "LOC" error depends on many factors, including which Elite model machine you own and the cause of the error. If your machine has an "Options" and a "Select" button, try pressing and holding these for five seconds to clear the locking error. You can also try unplugging the machine for five minutes and then plugging it back in
Nov 08, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore washer model44082 will not work. It flashed err and LOC. I have unplugged and tried to cancel.it still flashes err and then LOC.
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
Loc code frigidaire
Hold the LOCK button for 5-8 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite 45986 Front Load Washer
Error code ERR on Sears Kenmore front load washer
Jan 24, 2009 | Kenmore Washing Machines
Error code LOC on kenmore front load washer
Press/hold LOCK for 5 seconds.
Jan 08, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
775 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
