Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore oven heats what the oven says to 350 but when I test it with a thermometer is about 100 under that?And we just recently replaced bottom heating element.
  • 999 Answers
First check it make sure it is not programmed for Celsius. If not that then the sensor or the control is bad(or both).
eric
Posted on Nov 19, 2009
I cleaned my oven recently and no matter what temperature I turn the oven too, it cooks way too hot. I performed a test and set the oven temp to 100 degrees celsius. I inserted a thermometer into the...
If your burner always heats to "high" when it's on--regardless of how you set the burner knob--the switch contacts are shorted closed. Check the circuit for any other grounds, then replace the switch.
Apr 15, 2008 | Kitchen Ranges
I have a kenmore mark 1 oven in my apartment and the oven temperature says 1-9 instead of going in degrees such as 100, 350 etc. I am wondering which number stands for which heat?
This Conversion table is from the old Gas Mark scale
I'm thinking it should be right or at least pretty close.
You could also get a cheap ($5-7) oven thermometer from local grocery store.
Put it inside oven to check actual temp achieved.
Gas mark Fahrenheit Celsius
1⁄4 225° 107°
1⁄2 250° 121°
1 275° 135°
2 300° 149°
3 325° 163°
4 350° 177°
5 375° 191°
6 400° 204°
7 425° 218°
8 450° 232°
9 475° 246°
Apr 10, 2011 | Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
When i put my oven on to 350 it takes a long time to heat, then the beeper beeps to let me know the oven is ready BUT it is not at 350. I have an oven temperature gadget and it shows it is at 275. ...
Standard oven thermometers use a bi-metal coil, which is slow to react. When we test oven calibration, we use digital thermometers with a remote temp probe which are MUCH more accurate and MUCH quicker to respond to temperture changes. If your bake times are significantly longer or shorter than the recipes state, have a service technician test it.
Feb 19, 2011 | GE Kitchen Ranges
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Oven tempeture lower than setting by 100 degrees on 350. even after pre-heat cycle. slightly more accurate at higher temps. i have a regular oven thermometer to check it. it was working well until...
Hey-  Let's fix this thing.  Several things can affect indicated/actual temperature.  The temp probe should test ok across it's lead wires at around 1100ohms. The computer usually shows a fault if the circuit is open, but won't show a code if it hasn't failed completely.  The next suspect is the igniter for the oven burner.  These can become weak with age, affecting gas flow to burner. Testing igniter is not really possible when it comes on and the part is usually replaced.  The regulator is next in line, occasionally causing variable flow to burner.  As you can see, quite a bit to consider.  On site diagnostics is usually required, but this gives you a start.  Installation instructions are available for all parts.     Please acknowledge this post if my info and time spent helps you.  Have more info if needed.  Thanks- Ed
Mar 26, 2010 | Electrolux Ovens
Oven temperature does not regulate. The temperature is set for 350 but was 500 degrees in oven according to thermometer. Then sometimes you set it for 350 and it will get to almost 350 and then start...
From the symptons you describe, I would say that the oven thermostat is faulty, and in need of replacement.
Make sure your thermometer is o/k by checking it against another one, or boil some water, and check the temp of the boiling water, this should determine if your thermometer is o/k.
Hope this helps.
Dec 20, 2009 | Kenmore Ovens
Whirlpool gas oven shows to be almost 100-degrees off, according to cheap $5 hanging oven thermometer. Months before, showed F3 error after heating recently washed pizza stone, causing lots of steam. Did I...
Might have damaged the sensor. with the steam. There is a proceedure for adjusting the temperature reading but I do not think it will compensate for 100 degrees. i would replace the sensor.
Eric
Sep 28, 2009 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Oven doesn't heat
I'm not sure what properly means.  If the unit is working, you can get a cheap oven thermometer to check the function of the thermostat.  Let the unit come to 350 and check the thermometer.  If it is off by more than about 20 degrees, there is a calibration change method in most oven handbooks.
If the unit is not working at all, this is another issue and needs a different set of diagnostics.
Nov 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
123 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
