Question about Philips Magnavox 42MF521D/37 Television
TV will not turn on and has a continues to keep
TV will not turn on and continues to keep clicking
    Sergeant:
  • 295 Answers
Power supply issues. I believe bad Caps or Capacitors, Can be fixed.
A good tech can either replace the bad capacitors or replace the problematic power supply.
Posted on Nov 19, 2009
My LG TV KEEP CLICKING AND WONT TURN ON
Normally there are some capacitors in the power supply area of the circuit board that will be swelled up, on the tops of the capacitors they will be bulged out. it is a common problem. should work fine after replacing these capacitors.
hope this helps.
Feb 16, 2012 | Televison & Video
HP G71 Notebook PC - during a movie, screen keeps going black
Go to the control panel > Power Options > Select a Power Plan, look in the middle for Additional Plans, click on that and choose High Performance. Now, look in the left hand pane and click on "Choose when to turn off the display", make sure they all say never. Click on "Save Changes" and exit out of the page.
Jul 09, 2010 | HP VM114UA notebook
When I try to turn on my Samsung LN-T4042H LCD HDTV it is now constantly clicking in a continuous loop and will not immediately turn on. It started out small- a few clicks yesterday morning. Today it...
There is a problem with the power supply in your TV. The regulator switch is causing teh clicking sound you hear. In order to fix it, you will need to replace the power supply. This is done by taking off the back cover of the TV, locating the power supply which is usually a yellow board that will have many high voltage capicators on it and replacing it with a new one.
Nov 06, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
When you turn 'on' the tv...the tv continuously 'clicks'
The clicking noise is caused by the relays on the power supply board trying to power up the system. Your TV has detected a problem that's causing the power supply to shutdown. Someone knowledgeable in electronics can track down the problem. The SOURCE of the problem could be another board other the power supply.
Mar 15, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
My Hitachi Keeps Turning Off
Good Day,
There is no common problem with this TV for the problems you all described. So, I would recommend that you all call a Factory Authorized Service Center to come to your home and give a written estimate b4 any repair is performed.
Good Luck, big IRISH.
Mar 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TV WILL NOT COME ON
You might have a relay with bad contacts OR a loose or burned loose resistor in the power supply circuit. Stargazer
Mar 03, 2007 | Philips 32PT8302 32" TV
Philips Magnavox 42MF521D/37 Television Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
