Question about LG DU-62SY20D 62" Rear Projection HDTV
Hi.We have just purchased an LG 60' Rear Projection and the outlines are a bit fuzzy and the screen a bit blurry. What do you suggest we do? Its a 2nd hand TV. Thanx
    President:
  • LG Master
  • 1,779 Answers
It's possible your Light Engine needs replaced. I would have a service company take a look at it to be sure.
Posted on Nov 19, 2009
The screen turns red and fuzzy what does it mean
Cost of repair would be hard to say right off,depends on what the problem is. If its the Red Tube, sometimes shops will sale you a good used Tube, Problem could also be in the Focus block control depends on part cost and labor charges.Try adjusting the RED SCREEN Drive Control on the Focus Block turn level of RED Down ,then see what happens.
Oct 07, 2012 | Proscan PS60690 60" Rear Projection...
Print on screen is hard to read
When you say its hard to read are you meaning its sort of 3-D looking or is it like a glowing that makes it fuzzy only in certain areas. Let me know and I will assist you with the issue.
Jan 25, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is blurry with rainbow shadow
This problem is very common with rear progection TV's.
It is related to one or more of the colour guns being out of alignment. The only way to correct this issue is to have a technician come in and fix it or bring it into a repair center. I personally would suggest purchasing a new TV. The cost of getting them aligned is usually more then a basic LCD.
Hope this helps
Dustin
Jan 12, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Fuzzy picturethe
If the colors appear to be aligned and the only isue is focus, than you can adjust the focus on the flyback transformer. Carefully remove the rear cover and locate the flyback transformer (part with large red wire coming out the top). There should be 2 controls/adjustment points on it. One is for screen and the other for focus. Try adjusting the focus using a mirror to see the front of the set. You should adjust the control back and forth a ferw times to "loosen" it up a bit before settling down to the focus point.
Update this with the results.
Dan
Nov 30, 2009 | Zenith R57W46 57" Rear Projection...
My 60" Phillips tv has a blurry picture at the bottom and the top
The convergence output IC's need to be changed. A very common problem with all projection tvs.
Jun 04, 2009 | Philips 60PP9352 60" Rear Projection...
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Replacing Coolent
I have the service manual, and it looks like this is a bit of a job. You also need a special coolant fluid, not water. Still, I can't think why this would need replacement unless it has leaked out or you were replacing the picture tube. Are you sure it's not a focus problem?
Jan 13, 2008 | Philips 60PP9202 60" Rear Projection...
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
LG DU-62SY20D 62" Rear Projection HDTV Logo
111 people viewed this question
Computer Repairing
Computer Repairing
