Question about Philips 32PF5531D 32 in. LCD Television
The light showing power is on but no picture or response from the tv when i accidentaly hit channel one. It'll freeze to black screen. Any help getting it out of it?
  • Philip Frye
    Philip Frye May 11, 2010
    Is the LCD TV still covered under warranty?
  • Philips Master
  • 8,457 Answers
Unplug,replug an hour later,should be back to normal,if nothing burn in boards.
Posted on Nov 19, 2009
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Why did my sanyo 19" hdtv all of sudden went black? what to do now?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 12, 2014 | Sanyo DP19647 19 in. LCD TV
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
No picture. You can see some of the picture if the light is hitting the TV at the proper angle, but otherwise it's as if the brightness \ contrast is too dark.
It appears that back light is not working in tv so tv shows black screen/ no picture.
Possibly power supply board could be defective OR back light inverter board got bad, power supply board is available in shopjimmy.com on reasonable price.
Thanks.
Jun 12, 2011 | Vizio 42 in. LCD TV
I hit the wrong button on the remote - took me to a Dish option - I chose to exit. The screen is now black and blank, no matter what I do - no response. I went back to TV and chose channel again, but that...
Hiaschulte274 my name is Mike Houston of DISH Network, there are some things youcan do it get back to your programming. The first thing you will need to do isunplug the receiver for 10 seconds and after plugging it back in it will powerup and once you see the green light on the receiver you will want to go tochannel 3. If you still see no programming go through the different inputs onthe TV. I will send a link to help show how to resolve this issue as well. http://www.dishnetwork.com/SupportSection/bbs-screen
Jun 12, 2010 | DISH Network IR Remote Control
I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
Jun 18, 2008 | Samsung HL-R6167W 61" HDTV
Picture Problems
check for poor grounding of the input signal cable wire.
easy way to check this is put in a dvd and is that in color?
Feb 01, 2008 | Sony KP-53XBR200 53" Rear Projection...
Philips 32PF5531D 32 in. LCD Television Logo
129 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
