Question about RTO Allis Wc,wd Tractor Zenith Carburetor Comp 9797,10981a
Kit purchased did not fit. lost needle valve in shut off
    Sergeant:
    Champion:
  • 257 Answers
Not a expert just trying to help,, try going to the dealer of the tractor came from and get parts to the numer you have,, hope this help you
Posted on Nov 22, 2009
I have a 60 inch with a 25 hp kohler. It keeps filling the oil up with gas. It runs fine but after 30 min runnin the oil is full of gas
rebuild the carburetor float is stuck down . and while at it put a shut off in the line going to the carb
Mar 18, 2016 | Garden
Carb drain leaks?
This is caused by a bad needle and seat in the carb you can buy a carb kit and replace the needle and seat and it will stop leaking
make sure not to bend the float
Jul 19, 2014 | Polaris 2004 Sportsman 500 H.O
E-84 amway water filter
hi , providing you have the whole kit with the mounting head and sump or filter housing the head will have a flow direction, you'll have to cut your pipe and either sweat a fitting or use the provided adaptors usually quick connects, they can be purchased at local plumbing supply shops while your at it pick up some shut off ball valves for when the filters need to be changed. thread on the filter to chamber using rubber washer included. good luck , half hour tops ity will be installed.
Dec 06, 2013 | Amway A101, E84, E-85, E-9225 Compatible...
Corroded saddle valve
Shut off the main water valve and open some cold water faucets to relieve the pressure. Remove the entire saddle valve and make sure the piercing needle does not remain in the water pipe. Purchase and install a non self-piercing saddle valve and follow the directions. You will need a power drill and 1/4" drill bit for the install. Use teflon tape or paste on the treaded fittings. Test for leaks.
Jan 27, 2013 | Aprilaire 700 Humidifier
Fuel leaking from hose on bottom of carburetor
This happens when the float in the bowl sticks open. On a carborator the bowl holds gas. When the fuel pump fills the bowl the float raises and is pushing a needle valve that shuts off the gas until the float goes down and the needle valve opens and adds more gas. sometimes is sticks or the needle valve doesnt seat properly. You should rebuild it, buy a carb rebuild kit for your type of carb. It comes with new needle valves, just remember how it came appart.
Good luck
Robert
Oct 04, 2011 | Motorcycles
GPZ 1000A1 1987 Fuel leaking into engine from number three Carb Tap not on PRIME. New genuine Kawasaki petrol tap repair kit fitted. has done this on two different sets of carbs ? Tried everything I know...
YOUR CARB FLOAT NEEDLE VALVE IS LEAKING. YOU WILL HAVE TO REMOVE CARBS AND CHECK. IT SOUNDS LIKE A NEEDLE VALVE IS DEFINETLY STUCK OR YOUR FLOAT IN THE CARB IS PUNCTURED
May 15, 2011 | kawasaki Ninja Zx7r Zx9r '94 To '04
When i pull the cord to start it gas is spraying out the exhaust. What is the problem
The problem is the needle valve inside the carb is stuck open causing fuel to fill the cylinder. This why gas is coming out of the muffler. You have to rebuild the carb but you have to determine if you have a walboro or zama style carb in order to get the right rebuild kit. make sure you get the full rebuild kit that comes with a new needle valve and adjust the needle valve so that its flush with the slot that it fits in. Also remove the spark plug and pull the starter until all the fuel is out of the cylinder.
Dec 07, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Converting a whirlpool dryer from lp to natural gas
Make sure the gas is turned off and the dryer is unplugged from the power source.The first thing that you will need to do is purchase a gas dryer conversion kit. Extreme care needs to be taken when installing the kit and making the conversion, since there is a very obvious safety issue if the kit is not installed properly. The kit will consist of a brass fitting with a nylon pin sticking out of it. This is called the blocking pin. At the gas valve and regulator you will remove the plug on the gas valve (called a leak limiter) and replace it with the fitting containing the blocking pin that comes in the conversion kit. That will change the gas regulator pressure setting from gas to propane.
Next, you will have to change the orifice metering plug in the burner. This does just what the name implies... it meters the amount of gas that enters the combustion area. The fittings that come with the conversion kit (blocking pin and orifice metering plug) are made of brass, which is a soft metal, and since they are being connected to a much harder steel, make sure that the fittings are not overtightened. I generally use some pipe dope on the threads. Once the conversion is completed, you want to check for leaks. I generally mix up some soapy water and spray it around the fittings to check for leaks. Look for bubbling which is a sign that there is a leak. The last thing to do is to reassemble the dryer. Start it up and make sure that it is operating correctly and that there are no obvious smells that would indicate a leak. If so, shut down immediately.
These are the basic steps for a gas/LP conversion. If there is any doubt that you feel comfortable making the conversion, then I recommend that you contact an appliance technician for assistance. Hope this helped and best wishes.
Sep 11, 2009 | Dryers
Craftsman chainsaw runs wide open all the time
It sounds like the needle valve in the carburetor is stuck open. The carburetor could just need a simple cleaning or you may need a new carb. kit.
If the carb. parts (needle valve, gasket(s), diaphragm, & small screen) are more than 3 to 4 years old, you should go ahead and buy the carb. kit. Otherwise just clean the carb. If you need advice on how best to clean the carb., just let me know.
Jim
Jun 11, 2009 | Garden
Porter cable pancake unit blows air after shut off.
those have a reed valve set up you need to pull the head off and you will see two strips of metal that are usually held down with two small screws each the one on intake side most likely you could get a rebuild kit cheap it will only have new reed valves maybe new screws for them a leather ring and a head gasket
Mar 14, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
RTO Allis Wc,wd Tractor Zenith Carburetor Comp 9797,10981a Logo
62 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
