Question about GE Refrigerators
Water not dispensing
Icemaker makes ice but water not dispensing
  • GE Master
  • 4,654 Answers
Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
Posted on Nov 19, 2009
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
Amigaman
  • 248 Answers
SOURCE: icemake not making water
At bottom hinge of freezer is the water line to door. Undo connection in line. It may be a quick connect. To undo push in on one end flange to release, and pull out line. Put bowl under end from under refrigerator and make sure doors are closed. Now push water dispenser and see if water comes out line. If it does, the line is frozen in the door. They had some models that had air leaks in freezer door. This causes insulation to freeze and water line freezes. Push in on inside of freezer door and see if it sounds like snow crunching. If it does it's probably frozen. Also peel door seal back a bit and see if is held on by numerous screws. If it is, it may be one of them that freezes. Call GE. They may still have the program going where you get 2 new doors free. Give them your model and serial numbers.
Posted on Nov 14, 2007
  • 10865 Answers
SOURCE: Icemaker does not make ice. Appears no water is getting to maker.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 20, 2009
localwonder
  • 6784 Answers
SOURCE: HSS25GFPD icemaker stopped working. Blinking green light.
HI. First, you will need to rule out any standard issues that will cause this. Check the internal, and external feed lines for any obstructions. Make sure that the internal lines are not frozen, or kinked. If the lines check out ok, move on to the water filter(if equipped).
In most units, there will be a filter, present. These devices are set to operate on a particular time frame. If their filtering limit is met, the filter will stop filtering water, thus, not allowing the fluid to flow, at all. Make sure that the filter is up to date. If you have verified that the filter is ok, move on to the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to Remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. the multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Now. If the inlet valve is operational, and it has passed the above inspection, this will lead to a faulty inlet switch. This will be located, and mounted on the ice maker module board. First you must make sure of the design. Most ice maker control sectors are the module type and some are the traditional type. the traditional type is refereed to as a component ice maker. These are easier to work on. They have the gear components exposed, just behind the face plate. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. These are not serviceable. You will need to replace the entire module, if this is your type. The inlet switch is not accessible. The ejector motor, and mold heater are the only components that can be tested on a module style ice maker.
To determine which model you have, Remove the outer face plate. If there is a knob, pull it off first, then pry off the face plate with a small screwdriver. If it is a component style ice maker, follow the procedure below to test the inlet switch. if it is a module type, simply replace the entire ice maker. it is not repairable, due to the fact that the inlet switch is not accessible.
component ice maker inlet inspection procedure:(unplug the unit before attempting this inspection)
First you will need to Remove the entire ice maker form the unit.The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, Remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so already. Just along the the edge, nearest the shutoff arm, a pin protrudes through the mounting plate. The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker structure.
the inlet switch is located on the mounting plate, near the cam. the inlet switch is mounted on a thin plastic insulator and can be differentiated from the holding switch which sits on a thick spacer. the inlet switch also uses only two wires, while the holding switch uses three. Remove the switch by removing the two screws that hold it in place. The switch is connected by two wires. Label the wire placement on the switch before disconnecting the wires. The wires are connected to the switch with slip-on connectors.Firmly pull the connectors off of the switch terminals NOTE_ If the connectors are corroded, try to clean them. if the connectors cant be cleaned, simply, replace them.
Now, it is time for the testing section of the procedure.Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Touch one probe to the side terminal and the second probe to each of the other terminals. The reading should be zero on one terminal and infinite on the other. Now, repeat the test while depressing the switch, the readings should now be the reversed. If the switch fails the test, it should be replaced.
* NOTE_ If you have the component type, i would verify motor functions, as well. Test the motor for continuity using a multimeter. Set the multimeter to the ohms setting X10. Touch one probe to the wire from the wire cap. Touch the other probe to each of the two other wires in turn. The reading should be between infinity and zero for each wire.If the motor test results in a zero or infinity reading on either wire, the motor should be replaced.
Posted on Jan 07, 2010
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Jennair jcd2289 side-by-side does not make ice
If you are getting water from the dispenser, then the water valve is good. The icemaker will need to be replaced since when the icemaker cycles and empties the ice tray, it should call for the water to refill and it is not doing so. Here is a link to the replacement icemaker.
Oct 16, 2012 | Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No Ice is being made
Ice maker solenoid ...side..water side ok replace
Aug 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
