Question about HP OfficeJet 6210 All-In-One InkJet Printer
How to print envelopes from the office 6210. From
How to print envelopes from the office 6210. From the feeder up top or tray below
SOURCE: Loading & Printing envelopes
Because of the design, I think you need to feed it manually. (unfortunately, one by one)
Posted on Jun 16, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
leroyal
  • 2120 Answers
SOURCE: making a copy
Open the document feeder and clean the scanner glass.
Posted on Feb 27, 2009
  • 121 Answers
SOURCE: How do you print envelopes on the Canon Pixma iP460
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Posted on Oct 09, 2009
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
How do I print envelopes on Office Jet 6500?
  • Flip up the printer's output tray to reveal the input tray below and remove any paper in the input tray. Insert up to five envelopes into the input tray, print-side down, and slide the width guide so it touches the edges of the envelopes but does not bend them.
  • 2
    Fold the output tray back down and flip out the extension piece at the end of the tray. Fold up the paper stop at the end of the output tray's extension to keep the envelopes from falling out of the output tray.
  • 3
    Click "File" at the top of the software program you are using to create the text to be printed on the envelopes. Click the "Properties" or "Setup" button in the window that opens, then click on the tab labeled "Paper/Features."
  • 4
    Click the "Type Is" pull-down menu and select "Envelopes." Select the "Size Is" drop-down menu and click on the size of the envelopes you have loaded in the input tray. If you do not find the correct size, click "Custom" and type the height and width in the window that opens, then click "Save."
  • 5
    Click the "Source Is" drop-down menu and select "Tray 1." Click the "OK" button at the bottom of the window to save your settings, then click the "Print" button to begin the print job.
  • Read more: How to Print Envelopes With the HP 6500 E709A ' eHow.com http://www.ehow.com/how_7439186_print-envelopes-hp-6500-e709a.html#ixzz18tq0C0JF
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
    Thanks, Joe
    Dec 23, 2010 | HP Office Equipment & Supplies
    Load and print envelopes
    Generally NO. The reason is they have a manual slot and rear exit that keeps the path nearly straight for things like envelopes, labels, cardstock etc so they dont have to make the turn from the tray and from the fuser to the fact down exit tray. If you need to do a mailmerge with numerous envelopes you could 1) print a sheet of labels and stick those to blank envelopes or 2) go to a more advanced machine that has envelope feeder capability. Even a used machine such as a Laserjet 4000 - you can find envelope feeders that just attach on easily for almost nothing on ebay.
    Jun 21, 2010 | Brother HL-2070N Laser Printer
    How do I print an envelope
    Step 1- Remove the output tray
    Step 2 : Load Envelopes
    To print one or more envelopes, follow these steps:
    1. Remove all paper from the paper tray, and then slide a stack of envelopes into the tray, with the envelope flaps up and to the left (print-side down), until they stop.
    2. Adjust the paper-width guide against the envelopes. Be careful not to bend the envelopes and do not overload the tray.
    3. Adjust the paper settings in the Printer Properties dialog box for envelopes. Click the Paper/Quality tab, then select the following print settings:
    Size is: The appropriate envelope size
    Type is: Automatic or Plain paper
    4. Select any other print settings that you want, and then click OK .
    5. Print the envelopes.
    Regards,
    Riztech
    Mar 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
    Where to place envelope.
    This should be in your manual complete with pictures.
    You can print a single envelope using the photo/envelope feeder. Insert the envelope into the photo/envelope feeder with the side to be printed facing down and the flap to the left.
    You can print multiple envelopes (max 20) from the bottom tray. Temporarily remove the top (output) tray. Slide the paper guide in the bottom tray to the left. Load your envelopes to the far right with the side to be printed down, flaps to the left (I like to tuck the flaps into each envelope so they are less easily jammed, but this is optional). Slide the paper guide to the right snugly against the envelopes. Replace the output tray. Start printing.
    Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
    Dell 1700 only printing to envelope feeder
    make sure that the manual feed tray is not set as default make sure you main tray is
    Apr 30, 2009 | Dell 1700 Laser Printer
    Printing envelopes
    If you look closely at the very front of the paper tray, just to the left of the sliding thing that keeps the paper from drifting out of the front, you will see a couple of illustrations showing how to position envelopes in the paper feeder. For regular letter-sized envelopes, or even greeting card envelopes, place them face down with the top of the envelope pointing to the left as you are facing the printer. The return address area should be away from you. Position the envelope all the way to the right side of the paper feeder, then gently slide the envelope all the way back until it is stops so that it is accessible by the paper feeder. Bear in mind that it will be flipped over when it comes out. To avoid wasting an envelope, do a trial print on a piece of paper to make sure you understand the positioning correctly. Good luck!
    Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
    Print job will not print from the manually feed tray unless I select the Go button for it to process
    Table 3-7. Paper Handling Menu
    Item Values Explanation
    ENVELOPE FEEDER
    SIZE=COM10
    For supported paper sizes
    see page 1-12.
    This item appears only when the
    optional envelope feeder is installed.
    Set the value to correspond with the
    envelope size currently loaded in the
    envelope feeder.
    ENVELOPE FEEDER
    TYPE=PLAIN
    For supported paper types
    see page 1-12.
    envelope type currently loaded in the
    envelope feeder.
    TRAY 1 MODE=
    FIRST
    FIRST
    CASSETTE
    Determine how the printer will use
    Tray 1.
    FIRST: If paper is loaded in Tray 1,
    the printer will pull paper from that
    tray first.
    CASSETTE: A paper size must be
    assigned to Tray 1 using the
    TRAY 1 SIZE option (the next item
    in this menu when TRAY 1
    MODE=CASSETTE). This allows Tray 1
    to be used as a reserved tray.
    TRAY 1 SIZE=
    LETTER
    see page 1-12.
    This item appears only when TRAY 1
    MODE= CASSETTE. Set the value to
    correspond with the paper size
    currently
    Mar 12, 2008 | HP LaserJet 4350 Printer
    Envelope Feeder is not accepting the command
    > Home > Support & Drivers > Knowledge Base
    Solution --> Phaser 4400 Printer: Printing envelopes
    Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
    Guidelines for envelope printing
    • Use only paper envelopes.
    • Do not print on the back of the envelope.
    • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
    • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
    • Envelopes may wrinkle depending on weight and stiffness of the envelope.
    Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
    • Select faceup.
    • Clear Clockwise Rotation.
    • Select the feed method with the image centered and the stamp on the envelope to the upper left.
    caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
    note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
    1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
      • Place the side to be printed faceup.
      • The top of the envelopes should be toward the left of the printer.
    Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
    Paper / Envelope feed
    Envelopes Follow the steps below to load envelopes into this product. Lower the output tray and slide out the extension. Move the feeder guard towards you. While holding down its locking tab, slide the left edge guide so that the distance between the two edge guides is slightly wider than the width of your envelopes. Load envelopes short edge first with the flap side down, as shown in the illustration. Use the line on the feeder guard as the indicator when loading envelope. The right edge of envelope is aligned with the line on the feeder guard. Set the feeder guard back. Note: * The folding quality and thickness of envelopes vary widely. If the total thickness of the stack of envelopes exceeds 10 mm, press each envelope in the stack flat before loading. If print quality declines when a stack of envelopes is loaded, load one envelope at a time. * Do not use envelopes that are curled or folded. * Flatten the envelope flaps before loading. * Avoid using envelopes that are too thin as they may curl during printing. Extract from CX3200 user manual
    Sep 25, 2006 | Epson Stylus CX3200 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    63 people viewed this question
    Seeker5211
    Seeker5211
