Question about Acer Aspire 3680 Laptop
Acer aspire 3680 MONITOR backlighting problem.
My Acer aspire 3680 laptop display has turned dull red, i cant see the image correctly but when i connect it to a external monitor every thing works perfectly.
This happened as i was watching a movie, it initially turned yellow then the screen when dark but could see the image faintly but turned into dull red after formating and doing a new installation.
after checking on the net for possible problems, i found out that it might be either a burnt out back light or a bad inventer but that was for a dell laptop.
i want to know what is the cause for the change in my display and how can i fix it.
Am in Ghana/west Africa
please help am desperate
  • Anonymous Feb 28, 2008
    smae problem
  • Bellanz Mar 12, 2008
    My screen is just very dull. I'm not particularly knowledgeable about computers, all I've tried is adjusting the screen in 'Control Panel' in 'Display'. Help! I'm hoping its something simple I can correct myself. Thanks!
    Problem Solver:
  • 44 Answers
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 20, 2010
Dull screen can also mean, that you have changed your power settings to balanced or power for maximum use change it to full power.
Posted on May 03, 2008
    Problem Solver:
  • 19 Answers
Its u r laptop lcd problem.so please replace u r lcd
Posted on Jan 11, 2008
Acer Aspire 5610 LCD backlight problem
my laptop is acer extensa 4620 problem is web cam is not working what will do
Nov 05, 2009 | Acer Aspire 5610-4648 Notebook
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Nov 05, 2009 | Acer Aspire 3680 Laptop
Hi, just turned on my acer aspire, and whilst power is going through it, the screen won't come on. is this a common problem?
Does the laptop appear to boot up but cannot see an image on the screen?
If this is the case the LCD screen maybe faulty.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.lcdparts.net
Oct 07, 2009 | Acer Aspire 3680 Laptop
Acer 4520g minitor blackout
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 14, 2009 | Acer Aspire 3680 Laptop
Problems with Acer Notebooks
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 07, 2009 | Acer Aspire 3680 Laptop
Sometimes no display on screen of acer 3680 when starts
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
May 18, 2009 | Acer Aspire 5050-3242 Notebook
My Aspire 3680 laptop screen cannot appear properly
Try removing the plastic above the keyboard and wobbling the cable going to the monitor. Is the backlight appearing to work at all?
Apr 23, 2009 | Acer Aspire 3680 Laptop
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Picture flickering with dim display.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Acer Laptop Dark Screen
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Acer Aspire 3680 Laptop
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3680 Laptop Logo
707 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
