Question about Canon PowerShot S2 IS Digital Camera
Got dropped. shutter won't work
Dropped camera shutter doesn't work but video does
Did you remove the battery and replace it after a few moments? this will "reboot" the camera, like a cold boot from a computer. Then try again. I can't believe a landing on the carpet would cause mechanical problems, but you never know.
Could be just a setting, and that will be restored after the boot.
Aug 27, 2014 | Olympus Cameras
Why does my Cannon 600D Shutter stays open and doesn't work
maybee you are shooting the camera at very low shutter speed try to check the shutter speed first . if this does not resolve the problem you may need to drop the camera and the nearest service center and have you curtain checked . you might have reached the maximum shutter count and this needs replacment
May 03, 2014 | Cannon Cameras
Shutter button does not work after camera was dropped.
You dropped it and that is the problem, it is junk. Repair cost will exceed price of good camera.
Oct 11, 2012 | Kodak Easyshare C1530 14 Mp Digital Camera...
Kodak easyshare c1530 won't take a picture
If you dropped it why even ask ? it is broken.
Oct 11, 2012 | Kodak C1530 Digital Camera
I have a nikon N2000 35mm slr, before it was fully functional, now the problem is, The shutter won't open/close but the rest of the camera controls are still functional. Camera wasn't set on B...
So I assume you have changed the batteries and made sure there isn't any corrosion on the contacts. If your mirror is flipping up but no shutter, it sounds like a bad shutter. Check the shutter from the back, then from the front behind the mirror. Look for abnormalities or residue. It is a great camera and uses standard batteries (!) but the 1/2000 shutter has a half life like any other SLR. If you are going to throw it out you may want to open the back and use a q-tip to drip a couple drops of 90% alcohol on the top and bottom (and sides) of the shutter. As a last ditch, I throw cameras or lenses in the toaster oven at 200° for 10 min. and retry (take out batteries and film). At the least it will kill any fungus at the worst it hardens some lubricants. It does make you feel like you are doing some specilized scientific work before you toss it in the trash.
Jan 07, 2018 | Nikon N2000 35mm SLR Camera
Shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
shutter is stuck halfway. when i open the lense the shutter drop. what can i do? please help me. there are no service center in my locality.
Dec 19, 2010 | Nikon FM10 35mm SLR Camera
Flash doesn't work
don't drop a D80. wrap the fabric clipped onto the camera (say for hanging around your neck, which is a bad idea because of heat.) around your wrist two to three times, EVERY time you use it.
Jan 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
