Question about Ovens
I have a Zanussi FCS061E4 combi steamer that wont steam The red LEd is lit on the bottom of the panel Can you advise on the problem
Rational combi master is not steaming showing "rES" on display.
This rES is a asking for you to Reset the gas. Check gas that it is on. If it keeps coming back, then you have a gas ignition problem.
Jan 09, 2016 | Combi Ovens
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
RATIONAL CPC GAS
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Oct 26, 2013 | Combi Steamer electric built in steam...
I need manual for electrolux combi oven cs20
You can down load one right from a google search for such.. You could also look up customer service for Electrolux and contact them by phone to request one but you may have to pay a small fee.
Jun 07, 2012 | Combi Steamer electric built in steam...
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
Nov 28, 2011 | Combi Steamer electric built in steam...
Not steaming
check the holes have not gummed up from residue in the steam. It builds up over time.
Oct 23, 2010 | Combi Steamer electric built in steam...
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
233 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
