Question about Texas Instruments TI-36 X Solar Calculator
Raise a number to the power of a decimal: 273.16^1.5
  • Texas Instru... Master
  • 7,993 Answers
Use the key labeled [Y to the x]
273.16 [Y to the x] ( 1.5) [=] should yield 4514.66631
Hope it helps.
Thanks for using FixYa
Posted on Nov 20, 2009
FX 82 es scientific calculator. How I get decimal expansion of numbers?
Meaning what, exactly?
If you want a decimal representation of an exact number, press the SD key to switch from exact to approximate (decimal). If you want to expand a decimal number in powers of 10, separate all the digits, multiply every digit by a power of 10 with exponent equal to its position as counted from the decimal mark -1. To the left of the decimal mark, the exponent is positive. To the right of the decimal mark, the exponent is negative. Sum everything
Example
345.678 =3*10^(3-1)+4*10^(2-1)+5*10^(1-1)+6*10(-1)+7*10^(-2)+8*10^(-3)
Jul 21, 2015 | Casio Office Equipment & Supplies
I need to calculate exponential to the power of a number with minos sign. I have a BA II Plus
Make sure you use the +/- key (located just right of the decimal point key) to enter a negative number. For example, to raise 3 to the -2 power, press 3 y^x 2 +/- =
Jan 13, 2013 | Texas Instruments BA II PLUS Financial...
How do i raise a number to the negative power for example 1.00625 to the -360 power
1 . 0 0 6 2 5 y^x +/- 3 6 0 =
+/- is the key just to the right of the decimal point key.
Jul 18, 2012 | Sharp EL-501WBBL Calculator
Where is antilog function in Casio fx-570ES PLUS?
A name can bring a lot of confusion. The decimal logarithm has an inverse function which is raising a number to a power of 10. It shares the same physical key as the logarithm LOG.
May 15, 2012 | Casio FX570ES Scientific Calculator
How do I insert exponent to my calculator?
To enter a power of ten, use the *10^x key, located on the bottom row of the keyboard between the decimal point and the Ans keys. For example, to enter 1.2 times ten to the third, press 1 . 2 *10^x 3
To raise a number to a power, use the x^* key, located just below the big round cursor pad, between the x^2 and log keys. For example, to calculate 2 raised to the fourth power, press 2 x^* 4 =
Mar 09, 2011 | Casio FX-115ES Scientific Calculator
When I substract log(2) from log(4) I get .301029957, the answer should be 2, what is wrong?
The answer for the problem log(4) - log(2) is actually 0.301, so the good news is that your calculator is working properly! Here's a quick breakdown of the solution for the problem:
1) We know that log(x) = N means that 10^N = x. So in this case, we need to find a number that 10 can be raised to in order to get 4 and 2.
2) To get a better idea of what the answer to the problem will be, we look at the scale of the numbers. 4 and 2 are both smaller than 10. In order to raise any number to a power and get a smaller number, that power must be less than 1. If the power was 1 or greater, the answer would be more than 10. Therefore, we know that log(4) is a decimal less than 1 and log(2) is a decimal less than 1.
3) Now we'll simplify the problem. A logarithm rule states that:
log(x) - log(y) = log(x/y)
We can use this rule to simplify the equation in the problem.
log(4) - log(2) = log(4/2)
Since 4/2 = 2,
log(4) - log(2) = log(4/2) = log(2)
4) Now to solve the equation, the only thing that must be calculated is log(2). This would be done on a calculator. In step 2, we analyzed that log(2) must be less than 1. Therefore, the calculator is correct with the answer 0.301.
Hope this helped!
Nov 30, 2010 | Texas Instruments TI-84 Plus Calculator
What do I press to get the exponent 3 on BA II PLUS? Thanks
To raise a value to a power, use the y^x key located just above the 9 key. For example, to raise 2 to the third power, press 2 y^x 3 =
Unlike most calculators, there is no dedicated key for decimal exponents. You will have to use the above procedure to raise 10 to an exponent.
Nov 09, 2010 | Texas Instruments BA-II Plus Calculator
I don't know how to use the calculator enough to figure scientific notations
Scientific notation is a number format that has the following structure (d stands for digit)
one digit decimal mark several other digits [times] 10 raised to power of exponent
d [decimal mark] dddddd...[x] 10^ (-) dd
Here are two examples the last two results. The number of digits after the decimal mark is select by the user depending on the number of significant digits in the data. The exponent can be positive or negative.
In you case, to enter x10^ you press the [EE] key (no 10 is entered) the sign of the exponent and the value of exponent.
Aug 22, 2010 | Texas Instruments TI-89 Calculator
How to use the exponent key on a casio fx 300ES calculator ?
The key to use for the square, and the cube are well marked and they share the same physical key (X to 2) or [SHIFT][X to 2]. Similarly the keys to use for the square root and the cube root share the same physical location (the square root key, to the right of the square key).
For any other exponent, including fractions and negative exponents you use the universal power key labeled [X to ] ( X with a raised square).
  1. You enter the base (the number to be raised to a power).
  2. You press the [X to ] power key.
  3. You close the parenthesis (the right one).
  4. You press [=]
Sometimes the result may not be displayed as a decimal number, but as a radical (if you take a root). To make sure it is displayed as a decimal number, in step 4 above, press [SHIFT][=]
Mar 13, 2010 | Casio FX-300W Plus Calculator
I'm trying to calculate base number equation
You are victim of a confusion between terms. Base-n calculations are calculations using various numeration systems (bases) : binary (2), octal(8) hexadecimal (16) and decimal (10). What you want is how to calculate powers, logarithms, exponentials and these have also the notion of base; Log in base 10 is the common log, whereas natural logarithms, are logarithms in base e.
Back to your exemple: 5 times 5 and raise the whole to power 3?
In that case [(] 5 [x] 5 [)] [^] 3 or [X to the 3] if you have such key or
25 [^] 3, because 5x5 = 25
5 times (5 raised to power 3)
5[x] [( ] 5 [^] 3 [)] or 5 [^] 4 because of the rules about products of powers with the same base.
Hope it helps.
Feb 17, 2009 | Casio FX-115MS Plus Calculator
Texas Instruments TI-36 X Solar Calculator Logo
48 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
