Question about JBL PB12 Subwoofer
I have a high pitch squeal coming from the subwoofer even with the input disconnected. The level is low but the pitch is like a varying whistle.
  • 11,361 Answers
You can have bad filter caps or the Class D module is going out. I mod my to fix shorted out Module, http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
Service manuals: Read them to see if you can fix it.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB12%20sm.pdf
Posted on Jan 18, 2010
I have a 2003 Jeep Wrangler that has a high pitch SQUEALING sound when I release the accelerator. Any ideas what's causing it or how to fix it?.
I know i have the same problem, and i also noticed than when i open the Hood the whistle just stops, so i figure out it must be some air cycling in or out osmewhere, I found out my air intake connected to throttle body was misplaced a weird gap was left open allowing air to whistle. u might wanna check there
Sep 19, 2012 | 2003 Jeep Wrangler
Emits high pitched whistling after unit runs for 30 minutes
Sounds to me like the bearings are going bad in the motor. The hotter it gets the grease breaks down and the squealing starts.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 30, 2017 | Haier CPRB07XC7 Portable Air Conditioner
Squealing noise (LOUD)
You need to check the pulley alignment of all the pulleys, they should all be in a perfectly straight line, otherwise the belt will squeal
Aug 24, 2017 | 1988 Jaguar XJ6
My KLH subwoofer (model ASW8-120B) has stopped working and emits only a low-pitched hum.. I have tried hooking it up using the ''high-level'' 2-wire inputs as well as the ''low level'' RCA plug inputs....
It's unlikely that you can find a shop to repair it for less than the replacement cost ($75ish for a comparable KLH or Sony sub)
If you're up for doing your own soldering, here's a solution for the same problem with the same amp.
If this helps, please hit the "thumbs up" for me!
Jun 26, 2010 | KLH ASW10-120 Subwoofer
1994 ranger in 3rd and 5th gears, it has a loud whine to it.
Mine has a high pitched whistle at high rpms and I can't figure it out. But mines def not the tranny. I'm thinking it's a vacuum line somewhere. It's a 97 2.3l manual. The colder it is the louder...
Apr 12, 2010 | 1994 Ford Ranger Supercab
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
1994 nissan pickup high pitch squeal when driving
it could be the engine belt or the brakes are bad listen to where it coming from and you will know which you have to change
Aug 18, 2009 | 1994 Nissan Pickup
Van brakes squeal/whistle even when stopped
Sounds to me like a dry, loose or worn serpentine belt. With the motor idling, lightly spray the serpentine belt as it's spinning with WD-40 or other oil based lubricant (Don't spray near the alternator). If this doesn't work, turn the mortor off and check the tension and for cracks or worn spots. The brakes will not squeal when you are completely still.
Jun 11, 2009 | 1999 Chrysler Town & Country
Jbl sub 150
Make Sure you have your Audio cables Connected right. Meaning Red with Red and White with White.
Aug 05, 2008 | JBL 5.1-Channel Home Theater Speaker...
JBL PB12 Subwoofer Logo
763 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
