Question about Acer Aspire 3690-2196 Notebook
Hi i have an acer aspire 3690 and cannot boot the pc as it says unmountable boot volume. i dont have the recovery cd or bios password as bought from someone i used to know in the uk and im no longer living there. please help
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
  • Bryan Abrameit
    Bryan Abrameit Mar 31, 2014
    i also have same problem and have tried everything...plz help...im using windows 7
Need to reset bios password acer aspire 3690
Hello
Get in these links. You will get information about how to change the password.
futuremark.yougamers.com/.../showthread.php?...bios-password...ace
www.recoverbiospassword.com/.../acer-aspire-3680-3690-bios-passw
http://www.dataentryjobs.us/67948.html
tim.id.au/.../acer/
Feb 04, 2012 | Acer Aspire 3690-2196 Notebook
How do i reboot my recovery partition from a aspire 3690
Hi
If you have the option to save anything like files and photo's stored on your hard drive you should do this before you attempt a recovery because you will loose all files it will format your hard drive
back to when you bought it
Normally when you hit the power key you also tap the ALT+ F10 key a few times until it gets you
into the acer recovery manager and when asked for a password try 000000 thats is ( 6 zero's ) and follow the on screen instructions
if the F10 option dont work
then restar laptop and tap the F2 key to get you into bios and go over to about the 3rd of 4th option
and make sure that the D2D is enabled if it is not then click on it and change to enable
then click F10 to save and exit
then go back and try the ALT+F10 keys again
Mar 22, 2011 | Acer Aspire 3690-2196 Notebook
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one, have en error realtek, somting about ethernet. then the windows don't go up. so start with the screen that said windows, and quickly appear a blue screen with a message unmountable...
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Aug 12, 2009 | Acer Aspire One PC Notebook
What function keys do i press on startup to re insatll the operating system on my acer aspire 3690
you can use the recovery disk which came along with the laptop to reinstall the OS. There is no function key to start the installation automatically, there is a backup / restore button in some laptops which can reset the OS. Check the manual for any such button on your laptop.
Jul 07, 2009 | Acer Aspire 3690-2196 Notebook
Acer aspire 3690 bios password
try to hit F10 or F12 for booting the windows..thanks..and good luck...^_^
May 13, 2009 | Acer Aspire 3690-2196 Notebook
I want to take my acer 3690 back to when i bought it
There is no way to roll back from Vista to XP. If you still have an XP CD Key you can re-install using a windows disk of the same type using your code. All the drivers should be downloaded first to a CD from the manufacturers web site. Plus any data you would like to keep.
Useing acer recovery discs
turn off your pc and boot up with the disk in the drive. watch the screen and when it says (boot from cd press any key) do it if it dosent say that. reboot and get into the bios and change the boot order so the disk drive is before the hard drive, save changes and reboot. than press a key when it asks
good luck
Jan 24, 2009 | Acer Aspire 3690-2196 Notebook
Locked out of my laptop forgot my users password
I have the same computer and I done the very same thing. Do you have the recovery disks that it came with? If so you need to take a paper clip and open the drive by pushing the paper clip the small hole in the cd drive door.... If you cant get the drive door to open. Try running your disks from 1-7. This should at least get you to the BIOS. Set your Boot order to where the 1st line says from CD drive. Then you should be good to go to factory settings.
If that does not work if you have a 98, Ultiamte Boot Utility, Vista Bootable CD, They can boot your system and format your hard drive whatever you want to do. You will lose all your data but at least you will be able to use it.
Jan 14, 2009 | Acer Aspire 3690-2900 Notebook
Acer Aspire 3690-2196 Notebook Logo
369 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
