Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Rattles like rocks in it when going to spin cycle! Less than 2 yrs. old
    Guru:
  • 1,738 Answers
Your load is uneven, try spreading the load evenly before spin cycle.
Posted on Nov 19, 2009
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
When it spins, the washer makes a loud noise. it rattles. Also when it is doing the rinse cycle I can hear a vibration/rattling noise.
I'm sorry to say that tis is potentially very bad news. the problem you describe is almost certainly because the main bearing on the drum is worn out, allowing the inner drum to "flop about".
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. If the bearings are bad enough then symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is the result of the failing bearing allowing water to escape through the seal at the rear
Jul 07, 2011 | Maytag Washing Machines
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
There's an extremely loud noise during the spin cycle. Sounds like a rock or screw rattling around in side the machine.
WELL ITS VERY SIMPLE TO FIX ALL YOU HAVE TO DO IS TAKE YOUR LEFT LEG AND XTEND TO GROUND FOLLOWED BY YOU RIGHT NOW GO AHEAD AND HOP DOWN....NOW PLEASE TRY TO REMEMBER THAT SPIN CYCLE IS FOR CLOTHS ONLY...YOU HOUSE WIFES ARE SOOO FUNNY
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
308 people viewed this question
Dan Webster
Dan Webster
Sal De
