Question about Vizio P4221 Television
Red stripe on vizio 42"
I have a Vizio 42" that i purchased in 2005. Yesterday a vertical red stripe(about 2 inches wide) appeared on the left hand side of the screen. i have been told it is the processor, but im not sure...if it is in fact the processor, how much would a new one cost, and where could i find one?....
Thank You in advance,
Richard Kelly
  • 5 more comments
  • lmhursey Feb 15, 2008
    We just had the same red stripe appear on our P4221 42" plasma that we purchased 2 years ago as well.  Except our stripe is on the right side.  We too are interested in what is involved in a fix.
    Thanks in advance,
    Lois Hursey
  • HVAC Tch Apr 17, 2008
    I have the red stripe problem which is located on the left side about 2 inches wide, bright red against dark screen gets more transparent as the picture on the screen lightens. I have contacted Vizio online support. They have not offered up a true fix, but I can get it to go away by going in to the menu and doing a reset in the set up tab. After doing a reset the red stripe disappears with in about 20 minutes and does not appear again until the set is turned off and turned back on. I suggest you go to Vizio.com and let them know about this. Maybe they will then know it is a common problem
  • Wayward12 Aug 30, 2008
    Same this more orange than red, ride side about two inches wide. Any thoughts?
  • alfiku Sep 15, 2008
    I have the same problem but worse: first red 1" stripe appear on the righ side, then a blue 1" stripe appear beside the red one and finally another red 1" stripe appear but now on the left side and to end the first red stripe increase to 2" width. It's the end of the plasma life? I'm only use it around a 7k hrs.
    Thanks in advance, Alfonso Figueroa from Tijuana Mex.
  • Anonymous Oct 12, 2008
    red stripe about on the right side of the screen. Appears then disappears at random. It is just above the green power light on the screen. That side of the TV has a higher temp in the back as well. WTF? no problems before this and all of a sudden...
  • Troy Bartolo Nov 05, 2008
    I have a VISIO 42HD. I purchased it just under two years ago. A red transparent vertical stripe, about two inches wide, six inches in from the left side of the screen now appears. It extends from the top to the bottom of the screen. Is there any hope of repairing it?
  • Anonymous Dec 09, 2008
    Our two year old Vizio just started showing a 2 inch wide, vertical, red stripe on the left side of the screen yesterday.  It stays there even when we switch to other inputs.  Any solution?
DRACO A5OG
  • 22 Answers
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
Posted on Dec 23, 2008
DRACO A5OG
  • 22 Answers
SOURCE: approx 1.5" wide vertical blue line 5" from left side
Took out the OEM 6871QCH038A (038A), it is the last board after you pull the cover, bar, top input board, sits right behind the aluminum shield of the plasma screen. Caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glass to check those little resistors. They all checked out, no broken solders.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 6781QCH060Q (060Q) is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
Posted on Dec 24, 2008
phongnv
  • 56 Answers
SOURCE: Plasma Vizio 42 inch
The main board of your TV is bad. I have seen a lot of TVs have the same problem.
Posted on Feb 17, 2009
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
  • 115 Answers
SOURCE: 4 year old vizio 42 plasma has a two inch vertical
suspect panel logic board . you did not give the model number?
Posted on Oct 06, 2009
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
Vertical red line on my Vizio plasma
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
Feb 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
One verticle line appeared
Same thing happpened to us with a Vizio 26" TV. Its a defective panel,and cannont be fixed, we were told. Vizio replaced the TV under warranty.
Nov 22, 2008 | Olevia LT27HVX 27 in. LCD Television
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Oct 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P4221 Television Logo
441 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
