Question about Panasonic Workio DP-2330 Printer
After formatting my computer, my computer does not recognize the drivers anymore when i try to install it again.
    Sergeant:
  • 310 Answers
After formatting, you will lose any drivers that you loaded before. You can find drivers for this printer here: http://www.panasonic.net/pcc/support/mfp/dp-3030/index.html
Posted on Nov 19, 2009
Why is it "stuck"?
One of the reasons of Hard Disk is not being recognized by the computer might be because the SATA driver was not properly installed by your system disk
Read this tutorial
The BIOS does not detect or recognize the ATA SATA hard drive
There are some youtube tutorial too. Do a search for Hard disk not recognized by BIOS
Hard Drive not Visible in My Computer How to Fix It Full Version
Now, I posted these two initial links just not to depress you. My experience is that when this happens means that it DIED. you can't do anything with a hard disk if it's not recognized by the computer.
So, if everything fails get yourself a new Hard Disk.
Internal Hard Drives
Jul 25, 2015 | Computers & Internet
My battery wont recharge when i plug it into the computer
IMPORTANT: To function properly, your Walkman® player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media® Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
NOTE: If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below: Check for available space on the player using Windows Media Player or My Computer . Restart the computer. Check the connection status again and try to sync the player. Check that the USB cable is firmly connected to both the computer and the player. Check the connection status again and try to sync the player. If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable. Check the connection status again and try to sync the player. If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer. After the computer restarts, connect only the Walkman portable player and test the connection again. If the player is still not recognized by the computer, try a different USB port. Check the connection status again and try to sync the player. Under the Common settings menu of the player, format the player using the built-in Format utility. Check the connection status again and try to sync the player. Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system. If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later. If you did not have the latest service pack, test the connection status again after it has been installed. If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Sep 22, 2009 | Sony Walkman Video NWZA818 MP3 Player
Changed my hard drive on my toshiba satalite p205 s6347
If its XP your trying to install, XP does not recognize SATA drives on its own (probably why the install disk does not see the drive), you will need to install third party drivers on the F6 prompt it gives during setup.
You need to download "Matrix Storage Manager", and format a floppy disk for the drivers to go on so a USB floppy drive is needed for this case for the AHCI/RAID drivers unless you know how to integrate them into the install CD itself.
You can download Matrix Storage Manager from Intel here >>>>>>>>>>>
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2101&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Make sure you read all the read me files pertaining to setting up the floppy disk for use with the F6 prompt as you will need to format the disk in the FAT file system.
Once you have the third party drivers installed the setup disk will recognize the SATA hard drive and allow you to install XP.
I would then recommend that you look into integrating the drivers into the install CD so you don't run into this problem again.
If you need anymore help or advice please post back.
Good luck.
Jul 09, 2009 | Toshiba Satellite P205-S6347 Notebook
Sound problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 26, 2009 | Asrock 775i945GZ Motherboard
Cannot reformat my USB 4gb kingston
the reason is ur pen drive has lost its capacity to store datas. u cant use that pen drive anymore and it cannot be formatted also. try for a new pen drive
Jan 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Rio Forge 256Mb Mp3 Player
was there any cd given along with the purchase of this player???????
Feb 28, 2008 | Rio Forge Sport Digital Media Player
I cant get my computer to recognize the mp3, I just want to put music on it.
if your computer recognizes the device as a valid drive (look in 'my computer' folder for it) then you should be able to reformat it. Right click on the device in my computer, click format, quick format. set to FAT format if it lets you. run the format, then disconnect the device and power it back on. it should re-boot and then try to connect again. Try using windows medai player to transfer music. or download Rhapsody and try using that.
Jul 30, 2007 | GPX MW3816 MP3 Player
Panasonic Workio DP-2330 Printer Logo
52 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
